Wired Intelligent Edge
  • 1.  Downloading AOS-CX EVE-NG Compatible Image
    Posted Jul 15, 2021 04:16 PM
    Hello All,
    Could you please help me download EVE-NG compatible AOS-CX images? Are there any specific requirements to download the file ?
    It would be a great help if anyone can provide the same to me.
    Thank you for your attention to this matter.
    Azeem
  • 2.  RE: Downloading AOS-CX EVE-NG Compatible Image
    Posted Jul 15, 2021 05:27 PM
    Edited by mkk Jul 15, 2021 05:30 PM
    Hi Azeem,
    You can download the latest ova image from the website https://asp.arubanetworks.com. There is a small procedure needed to convert it into EVE but isn't that hard.
    Latest image here: https://asp.arubanetworks.com/downloads/software/RmlsZTplNTcyMTE2ZS1kNTJlLTExZWItYTg3Yy05NzAxZWNhNTNkMTM%3D
    See manual here:
    https://www.eve-ng.net/index.php/documentation/howtos/howto-add-aruba-cx-switch/
    Marcel Koedijk | MVP Guru 2021 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opionions are my own
  • 3.  RE: Downloading AOS-CX EVE-NG Compatible Image
    Posted Jul 16, 2021 06:07 AM
    Hi MKK,
    It helps surely.
    Could you please share the links for others products of Aruba like Routers and ClearPass for simulation.
    Thanks a lot for your time.
    Kind Regards,
    Azeem
    Azeem Ahmad
  • 4.  RE: Downloading AOS-CX EVE-NG Compatible Image
    Posted Jul 16, 2021 06:17 AM
    Edited by mkk Jul 16, 2021 06:19 AM
    All software like ClearPass can be downloaded from https://asp.arubanetworks.com.  ClearPass can be download as ova template but can't be integrated with EVE-NG and need to run on a hypvisor like VMware, Hyper-V. For ClearPass you need some trail licences that you can get from your local Aruba Partner for 90 or 180 days. For testing ClearPass use a physical switch.
    You can also take a look at the Aruba Work-Bench solution where you can use remotely lab testing time in the aruba datacenters. Not sure if this is for just partners or everybody.
  • 5.  RE: Downloading AOS-CX EVE-NG Compatible Image
    Posted Feb 03, 2025 11:07 AM
    Hello sir, please I can't download the ISO from Morocco it often gives me a problem with a message "Error during authentication, please log out and try again. Reason: Your account may need further review. If this problem persists, please contact Aruba Support for assistance 1-800-WiFi-LAN (US Toll Free) or +1-408-754-1200 (International)." you can upload iso to google drive so I can download it
