Wired Intelligent Edge
  • 1.  Downloading flash via console ,Xmodem
    Posted Jul 04, 2017 02:32 AM
    Hi all
    I am having some problems putting a new image onto a HP switch (2530-8G PoE) that has no primary or secondary image on.
    Switch starts up in Rom Mode
    I have tried to use console cable and xmodem to load it onto the switch but with no luck.
    My steps are
    1: Connect Switch via console cable
    2: Start up Tera term , connect to switch.
    3: Set swich baud speed to 115200
    4: Set Tera term to the same baud speed
    5: Write the do command to download image ( comes up with You have invoked the console download utility.
    Do you wish to continue? (Y/N)
    When I push Y nothing happens. So I going into Tera term and push trasfer xmodem send and choose file.
    still nothing happens. So I cancelled. Then I tried the do command again and pushed Y nothing happened then I dragged files into Tera Term console and I started. I thought YES its working.
    Then I got this
    ERROR: Download was unsuccessful. Rx failed @ffffffff
    Other info:
    When I push V for version: Build Date: 18:25:50 Mar 14 2016
    Version: YA.15.19
    Build #: 13423
    I have tried to change Baud speed all the way down to the default.
    I have googled the problem and think I have tried everthing. To me it seems like a problem at this point  when it  comes up with "You have invoked the console download utility.
    Do you wish to continue? (Y/N) " and when I push Y i would think it should come up with something.
    Hope someone has a solution
    Cheers
  • 2.  RE: Downloading flash via console ,Xmodem
    Posted Nov 27, 2017 04:32 PM
    I am having this same issue on a 2915-8G-PoE. Opened a support case, talked to a tech and he's supposed to get back to me. Did you ever get the new image loaded?
