  • 1.  Dropping clients
    Posted Aug 28, 2014 02:30 PM
    I have a weird situation.
    The setup.
    3 IAP-135's
    Factory_restored
    The issue. Clients get dropped, apperently when the AP decides to move them to another AP.
    The weird part is devices like a iPad will not reassociate unless you manually go choose it again. Its like the access point told the iPad to not even try connecting.
    I attached the config
    Attachment(s)
    zip
    instant5.zip   1 KB 1 version
  • 2.  RE: Dropping clients
    Posted Aug 28, 2014 02:31 PM
    Current firmware
  • 3.  RE: Dropping clients
    Posted Aug 28, 2014 02:36 PM
    Do you have client match enabled?
  • 4.  RE: Dropping clients
    Posted Aug 28, 2014 02:54 PM
    I had the issue with client match on and client match off.
    I factory restored, then just created 1 network. Just SSID/pass
    Very simple config.
    2 of the IAP-135's came from another system and I used the factory reset button to reset them before adding them to the system that already had a perfectly functioning IAP-135 as a controller. The issue began after i added the 2 additional access points. They all show up and everything works fine EXCEPT clients get dropped and do not automatically reconnect.
  • 5.  RE: Dropping clients
    Posted Aug 28, 2014 04:08 PM
    Do you mind sharing the output of "show tech-support"?  You could also open a ticket with Aruba TAC.
  • 6.  RE: Dropping clients
    Posted Aug 28, 2014 05:28 PM
    dump attached.
    Attachment(s)
    txt
    dump1.txt   801 KB 1 version
  • 7.  RE: Dropping clients
    Posted Feb 12, 2015 06:27 AM
    Was this ever resolved? We're seeing the exact same issue with our implementation.
