Wired Intelligent Edge
  • 1.  DSCP QoS Markings
    Posted Mar 24, 2019 06:47 AM
    Hi all,
    I have a fleet of 5400 series switches ... I was looking at honouring DSCP markings for QoS reasons at these switches out to our WAN.
    How can I honour DSCP markings and ensure certain ones take precedence over the rest of the traffic?
    I will have a simple QoS policy as our WAN only honours 3 different DSCP values
  • 2.  RE: DSCP QoS Markings
    Posted Mar 26, 2019 04:05 PM
    use qos trusted dscp on interface ?!
  • 3.  RE: DSCP QoS Markings
    Posted Mar 26, 2019 05:49 PM
    Thanks - worked nicely
    (ArubaS3500) (config) #interface gigabitethernet 0/0/21
    (ArubaS3500) (gigabitethernet "0/0/21") #qos trust <auto | dot1p | dscp | none>
  • 4.  RE: DSCP QoS Markings
    Posted Oct 10, 2019 04:20 PM
    Is it enough to configure the following command?
    qos type-of-service diff-services
    Is it still required to trust DSCP per port to apply DSCP-MAP?
  • 5.  RE: DSCP QoS Markings
    Posted Oct 10, 2019 05:15 PM
    Yes, the global command enables the DSCP trust ... then setting trust at each interface level ensures the trust is honoured.
    I usually just enter the command on all interfaces in one go ... ‘interface A1-f24’ etc etc then apply the command
