My understanding for Provision switches, the default mappings do not need to be defined; true?
Also, when set to a a 4 buffer queue, the
.1p pri TO
qos queue and depth TO
dscp priority map
goes something like this:
802.1p Pri 2
qos queue 1 - depth 8%
qos dscp-map 001110 priority 2
802.1p Pri 1
qos dscp-map 001010 priority 2
802.1p Pri 1
qos dscp-map 001100 priority 2
802.1p Pri 0
qos queue 2 - depth 17%
qos dscp-map 010010 priority 0
802.1p Pri 0
qos dscp-map 010100 priority 0
802.1p Pri 3
qos dscp-map 010110 priority 0
802.1p Pri 4
qos queue 3 - depth 30%
qos dscp-map 011010 priority 3
802.1p Pri 4
qos dscp-map 011100 priority 3
802.1p Pri 5
qos dscp-map 011110 priority 3
802.1p Pri 6
qos queue 4 - depth 45%
qos dscp-map 100010 priority 4
802.1p Pri 6
qos dscp-map 100100 priority 4
802.1p Pri 7
qos dscp-map 100110 priority 4
802.1p Pri 7
qos dscp-map 101110 priority 5
Is this corect?
So all i need to do to set the dscp map to a vlan is this:
vlan <VOICE_VLAN>
qos dscp 110100
True?
So if I am trying to get my voice into the highest percentage queue, is there any difernce between a dscp map of 100010 100100 100110 110100 regarding switch cpu time? If so, what?
</VOICE_VLAN>
