AP-605H can only get PoE from E0 and not E1. However you can test the LACP functionality, it could work
Original Message:
Sent: Jul 23, 2024 07:20 PM
Subject: Dual ethernet port AP600-series configuration best practices
Yes I read that in the manual as well, but it did not specifically mention the 600-series in the list of AP models.
Original Message:
Sent: Jul 23, 2024 07:13 PM
for IAPs, it happens by default. this is from the user guide
Original Message:
Sent: Jul 23, 2024 05:32 PM
I am not on AOS10, the access point is running InstantOn 8.0.10.13
Original Message:
Sent: Jul 22, 2024 10:49 PM
are you using AOS10 firmware for these APs?
but generally they can share PoE and have automatically enabled LACP on the APs. and it is good idea to connected to a stack of switches each port to a different stack member. With AOS10, a high-availability bonded link is automatically created that can operate in either active / active (LACP) or active / standby modes.
Original Message:
Sent: Jul 19, 2024 06:08 PM
When cabling AP-635 and AP-655 indoor switches to utilize both ethernet ports, attached to a four-node CX 6300M switch stack VSF, what are the configuration best practices? I am assuming an InstantOn configuration utilizing 8.0.10.13 as a minimum firmware rev.
I would prefer to cable each AP ethernet port to a different physical switch so that if a switch goes down, the other remaining AP port will be functional.
Ideally, I would like to utilize the 2.5G - 5G bandwidth of each AP ethernet port to get the most of the 6300M bandwidth available for less-than 100m short-runs utilizing CAT6A 10G capable cabling.
If I configure an LACP group on the switches that will give me primary/backup capability, are there options in the CX LACP configuration to utilize active-active so that both AP ports can be active simultaneously?
Is there anything special that needs to be configured on the AP end to take advantage of active-active?
