  • 1.  Dual Radio & Dual Band
    Posted Mar 06, 2013 03:40 PM
    what is difference between AP is  Dula Band & AP is dula radio ?
  • 2.  RE: Dual Radio & Dual Band
    Posted Mar 06, 2013 04:49 PM
    Dual band means it will work on both the 2.4Ghz and 5 Ghz bands but not neccessarily at the same time.  A dual radio means that there are two radios in the access point so one can operate at 2.4Ghz and the other at 5Ghz.
  • 3.  RE: Dual Radio & Dual Band
    Posted Mar 06, 2013 05:24 PM
    Just want to add some small bit of info: :smileyhappy:
    One of the main benefits of using Aruba Access point with Dual Radio&Dual Band is the Band Steering feature:
    (Old screenshot - but it will explain the basic idea)
    Have a lovely night. :smileywink:
    me
  • 4.  RE: Dual Radio & Dual Band
    Posted Mar 07, 2013 01:31 AM
    So can AP work with some clients on  a  while with other on b/g , while others on  n ...... is this related to dual band ?
  • 5.  RE: Dual Radio & Dual Band
    Posted Mar 07, 2013 05:36 AM
    Some access points have a single radio (AP93) that can be tuned to either a or bg
    Some access points have two radios (AP105), and one can be tuned to a and one can be tuned to b/g
  • 6.  RE: Dual Radio & Dual Band
    Posted Mar 07, 2013 04:43 PM
    Thx ,
    so AP like 93 can work on  either b/g  or a
    1-why is  "a"  separated from  "b/g"  ?
    2-what about  "n" ?
    3-is it better to work on  "a" or  "b/g" ?
  • 7.  RE: Dual Radio & Dual Band
    Posted Mar 08, 2013 03:29 PM
    you might want to do some general googling on wireless networks / radios / bands and such. there is lots of information out there.
    quick answers
    1) because a radio "works" on one or the other, a in 5ghz and b/g in 2.4ghz
    2) n can work on the a 5ghz or b/g 2.4ghz, it brings some tricks for higher throughput
    3) one could say a as it is less used, has more usable channels, and can do better channel bonding; but not all devices support it and the signal reaches less far, so with most things, it depends.
