  • 1.  Dual Uplink setup for Aruba 735
    Posted Nov 13, 2024 02:03 AM
    Good afternoon,
    My colleague and I are currently trying to set up our first dual uplink set up on our first Aruba 735. We are currently using Aruba Central and it's on 10.7.0.1. We have the BAGG setup on our switch with
    interface Bridge-Aggregation2
     description AP735 Test Aggregate
     port link-type trunk
     undo port trunk permit vlan 1
     port trunk permit vlan 920
     port trunk pvid vlan 1001
     link-aggregation mode dynamic
    We took two ports and added them to the BAGG and verified the port config on Aruba Central includes the two ports on AP (E0/1 and E0/0). The VLANs mode is set to Trunk on Central, Native vlan and allowed vlan are correct. LACP is set to Active in the AP options.
    The BAGG and ports all show up, but the mac address of the ap is not being passed along. The 735 is powered on but no radios since it's unable to get the ip address from IPAM. Is there an option I'm missing in the configuration?
  • 2.  RE: Dual Uplink setup for Aruba 735
    Posted Nov 13, 2024 12:37 PM
    It seems one of our wired network specialists recommended that the ports and the bagg need to be set up as access port's instead of a trunk setup. That brought the uplinks up and the ap began working.
  • 3.  RE: Dual Uplink setup for Aruba 735
    Posted Nov 13, 2024 12:38 PM
    Do you have a console cable for the AP so that you can check what is happening on there?  Might also try with the interface in access mode first to make sure that you aren't running into VLAN issues.
    Carson Hulcher, ACEX#110
  • 4.  RE: Dual Uplink setup for Aruba 735
    Posted Nov 14, 2024 08:01 AM
    Why utilizing Bridge-Aggregation when you have LACP ?
    Bridge-Aggregation (Static Link Aggregation):
    • Manual Configuration: Ports need to be manually configured on both devices that are being connected.
    • No Protocol: There is no protocol to manage the aggregation, so there is no automatic detection or negotiation of the ports.
    • Simple Implementation: It can be simpler to implement in small networks where you have full control over the configuration.
    • Limited Fault Detection: It cannot automatically detect and handle faults on individual links.
    LACP (Link Aggregation Control Protocol):
    • Dynamic Configuration: Uses a protocol (IEEE 802.3ad) to automatically negotiate and manage the aggregation of ports.
    • Automatic Detection: Can automatically detect and configure the ports that should be part of the aggregation.
    • Fault Handling: Can automatically remove a faulty link from the aggregation, increasing reliability.
    • Complexity: It can be more complex to set up but offers greater flexibility and robustness in larger networks.
    In summary, while static Bridge-Aggregation requires manual configuration and has limited fault detection,
    • LACP offers a more dynamic and automatic approach with better fault handling and flexibility.
    Steinar
  • 5.  RE: Dual Uplink setup for Aruba 735
    Posted Nov 15, 2024 11:38 AM
    Hi Steinar,
    On my second post, I mentioned that someone on our wired team had us change the settings slightly. I reviewed how to set up a dynamic LACP link, and it turns out that is what my team member had us do. We are trying to figure out how to get the wireless speeds closer to 2 Gbps than the 800 Mbps I'm seeing on my Samsung 24 Ultra. It's the only Wifi7 compliant test device we have.
  • 6.  RE: Dual Uplink setup for Aruba 735
    Posted Nov 15, 2024 11:43 AM
    Edited by chulcher Nov 15, 2024 11:44 AM
    LOL
    Take the AP and device into an RF isolation chamber, place the devices ~1 m apart from each other, utilize a SmartRate Ethernet connection rather than LAG,  and then test on 6 GHz with a 320 MHz channel.
