Hi all,
I am working on getting UPT to work on my 2930F & Clearpass.
Currently, I got stuck with downloading my user role.
The authentication of my test-client works fine and the following radius-response is sent to the switch.
Nevertheless, when running "
show user-role downloaded" no user role is listed and no tunnel to the controller is established.
When debugging SSL security I discovered that my certificate is marked as expired. My certificate is the root certificate from my windows testing pki.
As of my thinking the certificate should be valid, because it expires in 2521:
Is there another problem or is my root certificate the real problem?
Best regards
Michael
Michael
Michael
