Wired Intelligent Edge
  • 1.  DUR Role Parsing Failed
    Posted Jul 28, 2024 08:51 AM
    The environment is:
    R8Q70A 6200M 48G CL4 PoE 4SFP+ Sw  ML.10.13.1031
    CPPM 6.11.8.258602 with latest patches (20240430-radius-crash-fix-cphf-141 & 20240506-dur-enf-vlan-cphf-143)
    I am trying to push a basic DUR (simplified to only a VLAN assignment for now), but the switch is giving an error message:
    Type  : clearpass
    Status: Failed, Role Parsing Failed
    If I debug portaccess all, i see the following:
    Parsing the XML for the cprole DUR2-3061-2 failed
    I have an older 6.10 CPPM cluster waiting to be decommissioned, and if I point the switch to that with a matching policy everything works as expected.
    Is there any type of known DUR issue with CPPM 6.11 and CX 10.13.1031?
    I already have a support case open in parallel to this.
  • 2.  RE: DUR Role Parsing Failed
    Posted Jul 30, 2024 05:37 AM
    I'm not aware of such issues. Let's see what TAC comes up with. Please keep us updated.
  • 3.  RE: DUR Role Parsing Failed
    Posted Aug 12, 2024 08:35 AM
    I vaguely remembered that some xml parsing issue was presented in ACSX course and after checking the course material it indeed was: "When the XML result does not contain the correct commands, the "parsing xml failed" message will be shown". In the given example issue was caused by wrong credentials:
    Roy Lillqvist | ACSX #1421 | CCIE(RS) #38597
  • 4.  RE: DUR Role Parsing Failed
    Posted Aug 12, 2024 08:41 AM
    I fixed the issue, and believe it was likely mismatched credentials.
    Those commands would have been awesome at the time to confirm it was the credentials.      I'll bookmark them for sure.
