Dynamic ACL with ClearPass and comware switches
This thread has been viewed 35 times
  • 1.  Dynamic ACL with ClearPass and comware switches
    Posted Feb 06, 2019 09:20 AM
    Hi
    I try to configure dynamic ACL with ClearPass and Comware switche HPE 5130 HI, but it is not working as expected.
    It seems that switch get ACL ID succesfuly but ACL is without effect - no traffic is filtered.
    According with document Wired Policy Enforcement I send ACL-id from ClearPass with IETF:Filter-id attribute (in my case 3900) and switch shows that ACL as authorization ACL
    [B-GPD2-IT]disp dot1x connection
    Total connections: 1
    Slot ID: 1
    User MAC address: 34e6-d710-edf2
    Access interface: GigabitEthernet1/0/48
    Username: ZIAJA\kn_serwis
    User access state: Successful
    Authentication domain: ziaja
    IPv4 address: 192.168.18.12
    Authentication method: EAP
    Initial VLAN: 1
    Authorization untagged VLAN: 18
    Authorization tagged VLAN list: N/A
    Authorization VSI: N/A
    Authorization ACL ID: 3900
    Authorization user profile: N/A
    Authorization CAR: N/A
    Authorization URL: N/A
    Termination action: Radius-request
    Session timeout period: 10800 s
    Online from: 2019/02/06 15:00:32
    Online duration: 0h 1m 6s
    But there is no effect of this ACL
    ACL is as follows:
    Advanced IPv4 ACL 3900, 5 rules,
    ACL's step is 5, start ID is 0
     rule 20 deny ip source 8.8.8.8 0
     rule 30 deny icmp destination 8.8.8.8 0
     rule 40 deny icmp source 8.8.8.8 0
     rule 50 deny icmp
     rule 60 deny ip
    I entered more rules to be sure I filter all ICMP and IP
    My port config is as follows:
     port link-type hybrid
     port hybrid vlan 1 untagged
     undo voice-vlan mode auto
     voice-vlan 103 enable
     stp edged-port
     poe enable
     dot1x
     undo dot1x handshake
     dot1x re-authenticate server-unreachable keep-online
     dot1x timer reauth-period 7200
     mac-authentication
     mac-authentication re-authenticate server-unreachable keep-online
     dhcp snooping binding record
    802.1x and mac-auth is working fine
    Port works in 802.1x macbased mode
    It seems that in port-based ACL works ok
    I would appriciate any help
    Best regards
    Karol
  • 2.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 07, 2019 07:42 AM
    Hi Karol,
    The nas-filter-rule VSA is not supported on Comware. You have to configure the ACL's locally on the switches and use the IETF filter-id VSA.
    For example, if you have configured ACL 3000 on the switch, in the profile on ClearPass you set the IETF filter-id value to 3000. That should do the trick.
    Hope this helps.
  • 3.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 07, 2019 07:46 AM
    In addition to the response (I see that you are already using the filter-id VSA), I have also added the presentation that I gave during Atmosphere 2017.
    Attachment(s)
  • 4.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 07, 2019 04:24 PM
    Hi
    Thanks a lot for advices
    I have look at the presentation and I see that my port configuration is somehow different, I tried to use also port-securoty instaed of dot1x/mac-auth but with the same effect but there are also other port configs that are different and enforcement profiles
    However I used that sane profiles for 8021x and mac-auth
    I will make some tests and let You know about results
    Karol
  • 5.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 08, 2019 03:49 AM
    Hi Karol,
    Sounds good. The information in the presentation has been demonstrated during Atmosphere in 2017 so the configs in there should work fine.
    Kind regards,
    Dik
  • 6.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 12, 2019 06:47 AM
    Hi Dik
    Finally It came out that there was a bug in firmware on HPE 5130 HI switch. I found in Relese Notes for r1309p07 resolution of similar problem and finally after installation of new firmare it has started to work as expected.
    Now I have a little bit different problem with H3C Sesstion termination.
    Because after sending this enforcement profile to HPE 5130 HI switch, client sometimes doesn't reauthenticate again
    I use dot1x with mac-auth but sometimes with alone dot1x there is problem
    I have updated windows drivers and tested it on second laptop but it seems the same.
    I have switched now to Agent based Bounce ports
    I cannot do H3c Bounce port bacuse I have also telephone connected to port and it dosconnect
    Please advice, maybe I should contact Support ?
    regards
    Karol
  • 7.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 12, 2019 07:11 AM
    Hi
    One more thing
    I can't fight with thing that client authenticate every 30 sec although re-authentication is turned off
    I see in Clear Pass evert 30 sec entry with authentication for client connected to comware switch
    Do You know how to turn it off or change ?
    regards
    Karol
  • 8.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 13, 2019 05:22 AM
    Hi Karol,
    I don't have your configuration, but if you have Windows clients, you have to undo the dot1x handshake. Windows clients do not support handshake. If this is enabled on the switch, the switch checks every 30 seconds whether the client is still online. The client that does not support handshake, will not respond, and therefore this will trigger a re-authentication.
    Hope this helps.
    Dik
  • 9.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 13, 2019 05:56 AM
    Hi Karol,
    Checkout the videos that I have created on the ABC networking channel.
    ClearPass Captive portal with Comware 7:
    https://www.youtube.com/watch?v=yAd7ERfTbAY&t=23s
    This video contains the port-bounce functionality. In the video I am using the port-bounce, but if you don't want to shut/unshut the port you can also re-authenticate the session. You need to do this with the "[Cisco - Reauthenticate-Session]" action in the bounce policy.
    There's another video that shows you all the good stuff with MAC Auth/Dot1x for Comware 7 and ClearPass.
    https://www.youtube.com/watch?v=HeRIpF-x3nA&t=753s
    Hope this helps.
    Dik
  • 10.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 13, 2019 12:15 PM
    Please follow the ClearPass Solution Guide for Wired Policy Enforcement for a validated configuration on both sides.
  • 11.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 14, 2019 07:46 AM
    Hi Dik and Tim
    Thanks for responses
    I have watched videos and read document. Both are interesting.
    In regards with my problem to Session termination (CoA) I have defaulted port and then reconfigured from scratch and it seems works as for now. But a little bit strange...
    It seems I cannot use port bounce instead session termination because I have IP phone connected to the same port in tagged vlan and it disconnets (Avaya) with session termination.
    I have dot1x handshake disabled
    My port configuration is as follows
    interface GigabitEthernet1/0/48
     stp edged-port
     poe enable
     dot1x
     mac-authentication
    And I have authentication every 30 sec. as you can see in attachment
    But I have dot1x/mac-auth instead port-security
    By the way, what is advanted of port-security over dot1x/mac-ath?
    Regards
    Karol
  • 12.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 14, 2019 05:23 PM
    Hi
    Ok, I have turned to port-security and turned off multicast-trigger and turned on unicast-trigger
    I had a wrong device-type (Hewlett-Packard instead H3C)
    It seems to work now fine
    My port configuration is now a little long but hope fine, as follows:
    interface gigabit 1/0/48
     mac-vlan enable
     stp edged-port
     poe enable
     undo dot1x multicast-trigger
     dot1x unicast-trigger
     mac-authentication max-user 2
     port-security port-mode userlogin-secure-or-mac-ext
    And I havn't got every 30 sec authentication in CPPM :)
    Reagds
    Karol
  • 13.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Feb 15, 2019 03:06 AM
    Looking good. :-)
    Thanks for your response.
    Dik
  • 14.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Mar 01, 2019 10:22 AM
    Hi
    Unfortunately stiil one problem:
    After sending to switch CoA H3C termination Session my Ip phone looses connection,
    My phone is on tagged vlan and laptop on untagged
    Phone is authenticated with MAC-based,
    laptop with 802.1x
    is this a bug which I should contact to TAC or is it normal ?
    Should I use CoA in different way ?
    I temporary use Agent bounce port instaed CoA, but I would prefer CoA
    My phone is Avaya 1616
    Please advice
    Karol
  • 15.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Mar 01, 2019 10:29 AM
    Terminate Session is a Disconnect, not a CoA.
    The Disconnect should only apply to the MAC address for the session, so the
    phone should not disconnect if you're attempting to disconnect a downstream
    device. Please open a TAC case.
  • 16.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Mar 01, 2019 10:38 AM
    Hi
    Thanks for fast answer and explanation
    I will contact TAC
    Do You see any alternative to my config, maybe only send different VLAN with CoA ?
    regards
    Karol
  • 17.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Mar 01, 2019 10:45 AM
    I don't know if Comware supports a VLAN via CoA.
  • 18.  RE: Dynamic ACL with ClearPass and comware switches
    Posted Mar 03, 2019 03:20 PM
    Hi Tim
    Thanks for response
    I'm a litlle bit confused about my configuration, probably I must contact Avaya or HPE TAC.
    Now I'm not using terminate Session for PC (I'm using Agent based port bounce), PC and phone connects and authorize but Avaya phone dosconnects after some time (some minutes, some 10 min)
    I see that option multicast trigger changes behaviur on port for telephone.
    regards
    Karol
