I need to upgrade two 5406zl switches. Currently they have:
Primary Image : 14844423 10/09/11 K.15.06.0008
Secondary Image : 14844423 10/09/11 K.15.06.0008
Boot ROM Version : K.15.19
The release notes suggest I can upgrade directly (ie it says if your model is not listed, you can upgrade directly), however the summary at the ROM download page suggests I need two intermediate steps:
K.13.58 or newer: Update into software version K.15.15.xxxx
K.15.15.xxxx -K.15.16.xxxx Update into software version K.15.17.xxxx or K.15.18.xxxx
K.15.17.xxxx - K.16.01.xxxx Update directly into software version K.16.02.xxxx
I would appreciate any suggestions.
Thanks!
#upgrade#ProCurve#J8697A#5406
