  • 1.  EAP-Bio
    Posted 7 days ago
    Anyone aware of an upcoming or existing protocol for the use of biometrics for WiFi authentication with a back-end directory (possibly Active Directory or others)? Let's call it "EAP-Biometrics" or "EAP-Bio" for short. (If that name takes off, I want credit.) It would need to be a standard so that it would be rolled out by all of the device manufacturers, OS manufacturers, carriers, etc and baked into the configuration of each device (Microsoft, Apple, Linux, Android, Laptop, Tablet, Phone, and IoT Devices too). I would imagine this would require each device to have and make use of some type of TPM chip for the secure storage of the biometrics with a software interface to assist with the collection of the facial recognition picture / fingerprint data. The only kind-of somewhat comparable "Passwordless" protocol (as our identity guys refer to it) would be EAP-TLS where a client certificate replaces the password for the device.
    Brad
  • 2.  RE: EAP-Bio
    Posted 6 days ago
    I think you mentioned the answer already. You can use client certificate with protected storage and protect/control the use with biometric (fingerprint, face, etc.); ideally in a/the TPM or physical smartcard.
    Be aware that when connecting to the network, it may be quite user-unfriendly to require manual steps like biometrics. It causes delays and interruptions to the network connection. One additional approach is to use short-living client certificates, then use biometrics verification during the enrollment phase. In that case, at least while the certificate is valid, there is immediate authentication without delays.
    Maybe others have found something that works well?
