I think you have another post around that Bad search filter for computer authentications. Please resolve that issue before further troubleshooting this one. First make sure that you can do normal computer authentication with EAP-TLS, then switch to TEAP.
May be best to get Aruba support involved to get this investigated.
Original Message:
Sent: Oct 21, 2022 04:09 AM
Subject: EAP-TEAP method
I'm trying to implement EAP-TEAP as per the bellow :
Aruba ClearPass Workshop (2021) - Wireless Access #7 TEAP Authentication (EAP Chaining)
What i cannot get is the Computer Authentication although i have the correct certificate on the machine.
Should the Identity be checked (anonymous)?
The certificate authority should be the on-prem internal root CA or the issuing SubCA?
I noticed that computer authentication when appears gives :
2022-10-21 05:20:50,256 [Th 282 Req 462670 SessId R0000289d-01-63520201] ERROR RadiusServer.Radius - rlm_ldap: ldap_search() failed: Bad search filter: (|(&(objectClass=user)(sAMAccountName=LABPC$)) (&(objectClass=user)(userPrincipalName=LABPC$)))
2022-10-21 05:20:50,283 [Th 282 Req 462670 SessId R0000289d-01-63520201] ERROR RadiusServer.Radius - rlm_ldap: ldap_search() failed: Bad search filter: (|(&(objectClass=user)(sAMAccountName=LABPC$)) (&(objectClass=user)(userPrincipalName=LABPC$)))
Any thoughts?
