  • 1.  EAP-TLS auth
    Posted Jun 20, 2018 07:19 AM
    Hi All,
       I've tried to setup and EAP-TLS service on CPPM. I've installed the cert in the trust list.
    What authenticaiton source do I need to add in?
    Also I'm not sure my role mapping or Enforcement are correct, the user is getting this in access tracker -
    Endpoints Repository] - localhost: User not found.
    EAP-TLS: Authentication failure, unknown user
  • 2.  RE: EAP-TLS auth
    Posted Jun 20, 2018 07:21 AM
    Why do you have the endpoints repository as an auth source? That should be your identity store.
