Aruba Apps
  • 1.  EAP-TLS for VIA
    Posted Feb 22, 2013 03:28 PM
    We intend to put in place a EAP-TLS system for VIA authentication for our company and I would like to know what awaits us and pre-requisites. Is it easy to manage once installed? Do you have any suggestions?
    The use will be for Windows and iOS devices.
    Thank you!
    Alex
  • 2.  RE: EAP-TLS for VIA
    Posted Feb 22, 2013 03:43 PM
    The setup is covered in the VIA App Note on the VRD Site.   Refer to Chapter 5; specifically the section titled Configuring VPN Server for IKEv2; page 25.
    Considerations:
    - Do you have your PKI built
    - Do your controllers have certificates that will be trusted by the clients (same PKI or other is fine)
    - Certificates must be in the User store; not computer for Windows
    - The initial profile download for the client is done through username and password, not TLS
    - The controller cannot terminate PEAP for VIA authentications as it can for wirelss; your RADIUS server will need to do this
