most likely it is also fixed in 10.4.1.7 that was just released.
Original Message:
Sent: Mar 19, 2025 12:27 PM
Subject: EAP-TLS frequent disconnection since moving to AOS10/Central
The bug was resolved in the 10.7.0.2 code.
Antonio Saraca | Administrateur de réseau |  |  | 425, rue Blainville Est Sainte-Thérèse (Québec) J7E 1N7 450 434-1130 , poste x259 Cellulaire : +1 5148312524 | Avis de confidentialité Ce courriel est une communication confidentielle et l'information qu'il contient est réservée à l'usage exclusif du ou de la destinataire. Si vous n'êtes pas la ou le destinataire visé, vous n'avez aucun droit d'utiliser cette information, de la copier, de la distribuer ou de la diffuser. Si cette communication vous a été transmise par erreur, veuillez la détruire et nous en aviser immédiatement par courriel. |
Original Message:
Sent: 3/19/2025 7:43:00 AM
Subject: RE: EAP-TLS frequent disconnection since moving to AOS10/Central
Hi, did you find a solution to this?
Original Message:
Sent: Oct 31, 2024 07:15 PM
Tried AOS 10.4.1.5, 10.7.0.0 and 10.7.0.1 and problem is present on all 3 firmwares.
TAC confirmed to me today that they are opening an engineering ticket.
Original Message:
Sent: Oct 31, 2024 06:34 PM
what firmware are you running?
Original Message:
Sent: Oct 30, 2024 07:58 AM
Helle everyone,
We have a very strange issue since we migrated from AOS8 to AOS10 this summer: all our students laptop that use computer certificate authentification (EAP-TLS) are experiencing now constant disconnect/reconnect to our 802.1x SSID. What happens during the disconnect/reconnect phase is that the computer enters a "roaming storm" and roams to all AP that it sees, even the ones with a very weak signal. During this "roaming storm" the computer loses connection to the network from anyware of 3 to 15 seconds.
What is very strange is that the same computer, in the same location, is very stable on the network (stays connected to the same AP, no lost connections) if it connects to the same SSID but with a username/password instead of a computer certificate. Everything was super stable with AOS8.
We opened a case with the TAC but they are still investigating the issue.
I was curious to see if anyone else experienced or is experiencing this same issue.
Thank you,
Antonio
