  • 1.  EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 10:37 AM
    I've searched and searched and can't quite find a thread on here with the same symptoms. What I'd like to acheive is doing machine authentication with our Macs using a certificate assigned from our AD CA. I've got what I think is a very basic service configured, but the client keeps failing with "user not found". According to Access Tracker, it's not looking at AD as the authentication source even though it's specified.
    -Mac laptop (10.13.4) joined to AD
    -It's getting the AD, ClearPass, and trusted CA certs via profile manager (I'm 99.9% sure this is all working as it should)
    -AD CA cert installed in ClearPass trust list
    -EAP TLS with authorization checkbox unchecked
    -AD authentication source with default settings, working fine for EAP PEAP on production SSID
    What am I missing?
  • 2.  RE: EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 10:50 AM
    Remove the authentication source from your service.
  • 3.  RE: EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 11:01 AM
    Ok that works, but I had to change my role mapping rules. I had tried that, but my role mappings were based on AD attributes so it was still failing, just with a slightly different error message.
  • 4.  RE: EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 11:04 AM
    Just to be clear, this service is only handling machine authentications, correct?
  • 5.  RE: EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 11:06 AM
    Yes it is, but this is only a test service. The plan would be to eventually add it to our production service which is now only doing EAP PEAP for user auth. I'm pretty sure I saw a config in an old thread for how to do that.
  • 6.  RE: EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 11:09 AM
    It would be better to keep machine auth in its own service since authorization is not enabled.
  • 7.  RE: EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 11:15 AM
    Makes sense. Is there a way I can do that if it's using the same SSID?
  • 8.  RE: EAP TLS with ADCS for machine auth
    Posted Apr 26, 2018 11:23 AM
    Yes, services are not tied to SSIDs.
    Use service rules that check for:
    Authentication:Full-Username BEGINS_WITH host/
    Authentication:Full-Username ENDS_WITH .yourdomain.xyz
