Here is my video series on ClearPass that is referred to. I could not quickly see which video the original poster meant, but what was referred to is in Access Tracker the Input / Computed Attributes where you can see the information on the client certificate used:
If I read it correctly, the original poster could see from this that no, or the wrong certificate was used. I don't have a video specific on JAMF.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 14, 2025 02:45 PM
Subject: EAP-TLS with JAMF PRO extension
Any chance someone has a link to Herman's Video on this? I've seen it referenced in a couple threads but not sure where to look to actually view it.
Original Message:
Sent: Feb 10, 2024 08:50 AM
Our organization wants to switch all of our Jamf managed devices over to using cert based wireless authentication using eap-tls but I'm having a difficult time getting it to work.
I created a new service for EAP-TLS but when I see the attempt to connect in Access Tracker, I get the error "EAP-TLS: warning alert by client - close_notify
TLS Handshake failed in SSL_read with error:140940E5:SSL routines:ssl3_read_bytes:ssl handshake failure
eap-tls: Error in establishing TLS session"
I do not show the cert ever being presented to clearpass in "Computed Atrributes" like I saw in Herman's video. I can verifiy the cert is present in clearpass and on the supplicant.
I'm not sure where I'm going wrong. Can anyone help??
