EAP-TLS
This thread has been viewed 121 times
cappalli
cappalliJun 05, 2018 04:45 AM
  • 1.  EAP-TLS
    Posted Jun 05, 2018 04:43 AM
    Do I need to join and bind CPPM to AD in order to perform EAP-TLS authentication for a client?
  • 2.  RE: EAP-TLS
    Posted Jun 05, 2018 04:45 AM
    No.
  • 3.  RE: EAP-TLS
    Posted Jun 20, 2018 07:14 AM
       I've got a user testing this at the moment and its failing.
    They are getting -
    Alerts for this Request
    RADIUS[Endpoints Repository] - localhost: User not found.
    EAP-TLS: Authentication failure, unknown user
    Not sure I known how to point the authentication to the customers cert that I have installed in the trust list on CPPM?
  • 4.  RE: EAP-TLS
    Posted Jun 20, 2018 07:15 AM
    Why do you have the endpoints repository as an auth source? That should be your identity store.
  • 5.  RE: EAP-TLS
    Posted Jun 20, 2018 07:21 AM
    Hi Tim,
     It wont let me leave it blank - is there something else that should be there instead?
    I'm hoping to auth against the cert in the trust list - have I uploaded the cert to the wrong location?
  • 6.  RE: EAP-TLS
    Posted Jun 20, 2018 07:23 AM
    So you don't want to validate that the user account  actually exists in your identity store?
  • 7.  RE: EAP-TLS
    Posted Jun 20, 2018 07:28 AM
    No I dont think so, the customer doesn't have any link to AD for the devices so its just a match for a valid certificate I guess. CPPM Is a replacement for NPS - not being an expert I don't fully understand what they were checking and they couldn't explain fully.
  • 8.  RE: EAP-TLS
    Posted Jun 20, 2018 07:36 AM
    Create a new EAP-TLS method with authorization disabled.
  • 9.  RE: EAP-TLS
    Posted Jun 20, 2018 07:52 AM
    Hi Tim,
       I've created and added that to the service and it has a different error in the Alert tab -
    EAP-TLS: fatal alert by client - unknown_ca
    TLS Handshake failed in SSL_read with error:14094418:SSL routines:ssl3_read_bytes:tlsv1 alert unknown ca
    eap-tls: Error in establishing TLS session
  • 10.  RE: EAP-TLS
    Posted Jun 20, 2018 07:56 AM
    1) Remove all authentication sources.
    2) The client does not trust the EAP server certificate
  • 11.  RE: EAP-TLS
    Posted Jun 20, 2018 08:08 AM
    Hi Tim,
        I assume this means the ClearPass certificate? The user doesn't see any cert errors (perhaps they are not displayed). Should I get the user to install the CPPM cert in their trust list?
  • 12.  RE: EAP-TLS
    Posted Jun 20, 2018 08:10 AM
    Deploying certificates need to be carefully planned out and shouldn't be done with changes on the fly like this. Have you reached out to your Aruba partner?
  • 13.  RE: EAP-TLS
    Posted Jun 20, 2018 08:15 AM
    Hi Tim
      The client certs are already deployed, we are migrating the customer from NPS to CPPM. I am the Aruba partner, but none of the documentation on CPPM explains how to do what I've need to achieve here.
  • 14.  RE: EAP-TLS
    Posted Jun 20, 2018 08:22 AM
    The clients need to be configured to properly trust the EAP server certificate.
  • 15.  RE: EAP-TLS
    Posted Feb 10, 2024 08:28 AM
    I wish there was a step by step guide for those of us that haven't ever done eap-tls / cert based authentication with clearpass with apple / jamf.
    All the guides I see are for AD bound devices and sadly that doesn't help :(
  • 16.  RE: EAP-TLS
    Posted Feb 12, 2024 12:48 PM
    We are going to use the certs & consulting services of SecureW2 to implement EAP/TLS in our large campus environment.  More to report over the next few months.
  • 17.  RE: EAP-TLS
    Posted Feb 13, 2024 07:49 AM
    We are already wuite a ways down that path with SecureW2. Since this is a little off-topic, competing with CPPM OnBoard, please reach out to me in a PM.
    Bruce Osborne ACCP ACMP
    Liberty University
    The views expressed here are my personal views and not those of my employer
