Yes, you can use one of the LAN ports as a WAN interface. In the deployment page, add a new WAN interface and, for instance, select 'lan1' under the interface.
Technically, you can use any interface except 'mgmt' for LAN and WAN, regardless of their label on the appliance.
Original Message:
Sent: Feb 01, 2024 01:27 AM
Subject: EC-10104 with 3 WAN
Many thanks for your answer. I can see there are 4 ports, 2 LAN and 2 WAN. Do you mean we can use one of the LAN ports as the 3rd WAN ?
Original Message:
Sent: Feb 01, 2024 01:10 AM
Yes the 10104 has 4x copper Ethernet ports. You can use 3x ports for INETA, INETB, and LTEA then the fourth port for lan-side connectivity. If you have 2x 10104s in an EdgeHA pair you get 6 effective ports (one port on each 10104 used for EdgeHA link). You can then have INETA on 10104-Primary and INETB/LTEA on 10104-Backup.
Original Message:
Sent: Jan 31, 2024 12:20 PM
We want to implement Aruba SDWAN Edgeconnect EC-10104 device with 2 WAN inet1 and inet2 and a 3rd WAN (LTE) that will be the backup.
Is it something possible with the EC-10104 model ?
Many thanks by advance for your help.
