Edgeconnects will try to reach the portal over any interface. Mgmt0 is not required for normal operation on any model, but can be useful if you have a separate management network.
Have a look under the "management services" in either the templates of the local GUI. You'll find that management services are set for "any" interface by default.
Personally, I find mgmt1 more useful than mgmt0. On a default EC-10104 you'll see that lan0 acts as mgmt1 (i.e. set to 169.254.0.1/16)
Original Message:
Sent: Nov 28, 2024 02:27 AM
Subject: EC without mgmt0
You mean we dont need to use mgmt0 in this case?
Best Regards
Owais Iqbal
CCIE#37956 | ACDX
Technical Consultant - Aruba Networks
Mob/Whatsapp: +92-321-2960496
Original Message:
Sent: 11/28/2024 1:56:00 AM
Subject: RE: EC without mgmt0
If DNS is active on that link, then your device should be able to contact the orchestrator and receive its configuration.
 | Bart Dermul Kapt. CC V&C | +3224410756 Intranet |
Original Message:
Sent: 11/27/2024 11:29:00 AM
Dear Experts,
In a branch where there are 2 wan connections (mpls and internet) and 1 lan connection, how do we handle mgmt0? as far as i know we need mgmt0 to contact orchestrator. But in this case, what shall we do? i am kinda lost here.
iqbal
