SD-WAN
Edge Connect Enterprise trial license
  • 1.  Edge Connect Enterprise trial license
    Posted Jul 06, 2024 11:44 AM
    I want to learn Edge Connect Enterprise and install the Orchestrator as a vm and run different Edge Connect Devices in EVE-NG for easy simulations and different topologies.
    How can I generate eval licenses for this? If I look in HPE Aruba LMS I can generate a license for GMS (someone should change the text because it does not manage APs) but that does not generate a license needed in the Orchestrator which requires an Account name and Account key to the silverpeak cloud portal.
    You can test almost all of the HPE Aruba portfolio by creating eval licenses in LMS but I am not sure how to do it with EC Enterprise.
    Silverpeak Cloud portal
  • 2.  RE: Edge Connect Enterprise trial license
    Posted Jul 08, 2024 02:44 AM
    Trial licenses are available through your local SE. NFR licenses are available for authorized partners via the partnerweb.
    The (free) SD-WAN trainings include a voucher for a 2-day fully functional lab environment.
    There is a tool available that builds a lab environment for you on an ESXi server including the vSwitches, emulator, ECV's and the Orchestrator. You can do it on EveNG, but won't work smooth.
