Thanks @shpat. I will look into this and get back.
Original Message:
Sent: Apr 14, 2025 11:02 AM
Subject: Edge core to HP Comware port config
In this case, your PVID in TenGig1/0/16 is 106 <-> and PVID in ARG is 1, and i suppose both ports are part of a trunk configuration (or Hybrid) but mismatches are for untagged/native VLAN.
In this case either set Gigabit 1/0/1 to PVID 106:
interface GigabitEthernet1/0/1
port link-type hybrid
undo port hybrid vlan 1
port hybrid vlan 106 untagged
port hybrid pvid vlan 106
Or, if you want to keep VLAN1 , then change the Ten-Gigabit1/0/16 to 106:
interface Ten-GigabitEthernet1/0/16
undo port hybrid vlan 106
port hybrid vlan 1 untagged
Shpat | ACEP | ACMP | ACCP | ACDP
Just an Aruba enthusiast and contributor by cases
If you find my comment helpful, KUDOS are appreciated.
Original Message:
Sent: Apr 14, 2025 10:00 AM
Thanks @shpat.
I see this log message.
PVID mismatch discovered on Ten-GigabitEthernet1/0/16 (PVID 106), with ARG switch for 10.202.6.0/24 GigabitEthernet1/0/1 (PVID 1).
Do I need to do something more to fix this.
Original Message:
Sent: Mar 31, 2025 04:45 PM
I did use Hybrid port on a few occasions and it works so far without any issue.
Original Message:
Sent: Mar 31, 2025 07:08 AM
Thanks @shpat for your comments.
I found on couple of forum that its not wise to use Hybrid port commands. Not sure how much correct it is as I need tagged and untagged VLAN on the same port.
Original Message:
Sent: Mar 31, 2025 05:39 AM
To me it looks OK. I will try to compare it Line by Line:
To Allow VLAN 100 untagged
Edge-Core : switchport allowed vlan add 100 untagged
HP Comware: port hybrid vlan 100 untagged
To set Native VLAN to 100:
Edge-Core: switchport native vlan 100
HP Comware: port hybrid pvid vlan 100
To remove VLAN 1:
Edge-Core: switchport allowed vlan remove 1
HP Comware: undo port hybrid vlan 1
To allow VLAN 200 tagged:
Edge-core: switchport allowed vlan add 200 tagged
HP Comware: port hybrid vlan 200 tagged
So your config looks OK.
Original Message:
Sent: Mar 31, 2025 05:22 AM
Anyone can give me some tip for port config?
Original Message:
Sent: Mar 24, 2025 05:31 AM
Hi!
I am replacing Edge core with HP Comware and I have the below config in Edge core
I have come up with the below config HP comware
port link-mode bridge
I found on HP forum that that native vlan on HP comware is pvid.
I have tested the config and it works for untagged vlan and it still have to test it for tagged vlan 200.
Does the replacement config looks ok?
