SD-WAN
  • 1.  EdgeConnect Boost Not Granted
    Posted Oct 06, 2022 11:40 PM
    I got the error about Boost Not Granted in the License tab.
    But EC License configured and Granted was assigned correctly.
    My workaround is to remove the parameter Boost in deployment.
    Could you please explain it? I am still confused.
    Ratchapas
    https://www.facebook.com/Aruba-News-Update-1401095559960142
  • 2.  RE: EdgeConnect Boost Not Granted
    Posted Oct 07, 2022 07:16 AM
    Hi Sisant,
    Can you confirm your license page also shows you have an active Boost license.
    Check in your Orchestrator > Configuration > Licenses (left column almost at the bottom)
    What are the values under "Boost Gbps". Which release do you have?
  • 3.  RE: EdgeConnect Boost Not Granted
    Posted Nov 03, 2022 03:06 AM
    HI All,
    It is my mistake, the customer did not purchase a Boost license.
    Thank you for assuring me.
    Ratchapas
  • 4.  RE: EdgeConnect Boost Not Granted
    Posted Oct 07, 2022 08:58 AM
    It sounds like there was just a glitch when the license was applied.  You can confirm what you see in the Orchestrator by checking the local appliance gui to make sure it matches what the Orchestrator is showing you.
