EIRP / Conducted power IAP's
  • 1.  EIRP / Conducted power IAP's
    Posted Feb 28, 2014 05:23 AM
    Hello there ,
    is there a way to see the EIRP / antenna gain / conducted power for an IAP similar to a controller based AP using
    show ap debug driver-log ap-name (xxx) | include EIRP
    I am using IAP93 and IAP105 6.2.0.0 or later.
    id like to get a similar output to below
    594    765882.908704 wifi0: EIRP (Config: 18.0dBm, Set: 18.0dBm, AP Max: 26.0dBm, Reg Max: 23dBm), Conducted Power Set: 12.0dBm, Gain: 6.0dBm
    599    769044.918390 wifi1: EIRP (Config: 18.0dBm, Set: 18.0dBm, AP Max: 25.5dBm, Reg Max: 20dBm), Conducted Power Set: 12.5dBm, Gain: 5.5dBm
    but i cant find a CLI or GUI command to give me that information.
    I have tried ap tech support dumps and show ap driver-config, show log driver
    Im sure it must be possible.
    Any help appricated.
  • 2.  RE: EIRP / Conducted power IAP's
    Posted Feb 28, 2014 11:39 AM
    does:
    show ap bss-table
    show ap debug driver-config
    Help you at all?
