  • 1.  Enable 802.3at on AP 303H
    Posted Apr 11, 2022 10:44 AM
    I have AP-303H, This device is capable to provide Poe power output from one of the ethernet but I am not getting Poe output when i connect any device  . some documentation says that its require to enable 802.3at on AP. Here i need your help to  enable 802.3at power on 303H Access point .
    Thanks in advance
    Swajith lal
  • 2.  RE: Enable 802.3at on AP 303H
    Posted Apr 11, 2022 01:00 PM
    What's the input power source for the AP-303H? It needs to be 48Vdc or 802.3at POE.
    Also, POE out (PSE) is disabled by default and needs to be enabled.
    Onno Harms
