SD-WAN
  • 1.  enable inter-VLAN routing on edgeconnect
    Posted Feb 20, 2023 10:32 AM
    Hey,
    Performing new instalation with a client.
    I want to do vlan routing on the samen devices.
    Edgeconnect has 1 lan port with several vlan on it configured.
    Some with DHCP which is the edgeconnect itself, and some with a just a IP and subnet.
    Issues is that I need a connection from vlan X to vlan Y on same edgeconnect.
    Both vlan's are on the same edgeconnect.
    I can ping the default gateway of vlan Y via a device in vlan X.
    But I cannot ping a device in vlan Y.
    When I'm on the same subnet I can ping the device in vlan Y.
    Also on the edgeconnect ping tool I can ping devie in vlan Y.
    So how can I enable inter vlan routing?
    In the routes table I don't see any routes in local. (see attachment).
  • 2.  RE: enable inter-VLAN routing on edgeconnect
    Posted Feb 20, 2023 11:10 AM
    Hi Enzo,
    On my ECOS 9.2.2 testbed it works fine. Client on VLAN 2 can reach client in VLAN 4 and back. No need to configure anything specific. Just make sure the LAN side hosts have the EdgeConnect interfaces as their default gateway.
    The "Local/Static" tab on your Routes page won't have the local entries, but the tab "All" will have them as "Auto" entries.
    From the EC GUI you can make a packet capture. Make sure you select both LAN interfaces as shown in attached screenshot
  • 3.  RE: enable inter-VLAN routing on edgeconnect
    Posted Feb 21, 2023 04:52 AM
    I think found the issue.
    Devices behind silverpeak was acting as a router which redirect the traffic.
    Reason why I didn't saw any return traffic.
    Thx for the support already jkeinke!
  • 4.  RE: enable inter-VLAN routing on edgeconnect
    Posted Feb 21, 2023 09:21 AM
    This should just work.  I would double check Zone Based Firewall, and segments on the deployment configuration.  The best place to start looking is the "monitoring>flows" This will let you filter and see the ICMP packets and see what the appliance is doing with them and why.
    DuaneHenigin
