  • 1.  Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 17, 2023 03:29 AM
    Edited by gh.as Nov 17, 2023 06:12 AM
    Hello Experts,
    I would like to enable LACP(fast Rate)on 3 AP-535 in our Mobility Master (1 cluster with 2 controller 192.168.A.B-192.168.A.C).
    For this action in Huawei SW S5732 configured link aggregation and TRUNK them with LACP option (fast)
    in Mobility Master===>configuration===>AP Group and then LMS part I added IP address 192.168.6.x and Backup IP address 192.168.6.y
    Do I need also to use this ==> 192.168.6.x and Backup IP address 192.168.6.y to add them in
    Mobility Master===>System===>Profiles===>AP===>AP LACP LMS map information
    This also the current status of AP-535
    (MC1) [MDC] #show ap debug lacp ap-name ap-test-535
    AP LACP GRE Striping IP: 0.0.0.0
    AP LACP Status
    Link Status  LACP Rate  Num Ports  Actor Key  Partner Key  Partner MAC
    Up           slow       2          11         321          6c:34:91:42:61:61
    Slave Interface Status
    Slave I/f Name  Permanent MAC Addr  Link Status  Member of LAG  Link Fail Count
    eth0            f0:61:c0:cb:6c:2a   Up           Yes            0
    eth1            f0:61:c0:cb:6c:2b   Up           Yes            0
    GRE Traffic Received on Enet Ports
    Zone  Index  Controller IP  Enet 0 Rx Count  Enet 1 Rx Count
    0     0      192.168.A.B  0                91788
    0     1      192.168.A.C  0                0
    GRE Traffic Sent on Enet Ports
    Zone  Index  Controller IP  Enet 0 Tx Count  Enet 1 Tx Count
    0     0      192.168.A.B  15130            0
    0     1      192.168.A.C  0
    I have added the current situation of AP-535 which extract from Airwave.
    Best
  • 2.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 17, 2023 09:19 AM
    The controllers should be deployed as a cluster.  LACP striping configuration is not necessary when the AP is connected to a cluster, this feature is only functional when connected to a standalone controller or standalone controller active/backup pair.
    Carson Hulcher, ACEX#110
  • 3.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 17, 2023 09:35 AM
    Thanks for your hint. Then Aruba port mode in Active Standby is correct. Do I need to change it in SW ?
    Best
  • 4.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 17, 2023 10:21 AM
    The AP will operate in active/standby when dual connected by default, if you want LAG then configuration for LACP is required for the AP to bond the Ethernet connections.
  • 5.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 20, 2023 02:10 AM
    Thanks for your clear answer,
    I have configured our SW in right way, but still I can see in Airwave one port in Active Standby mode. Is there any way to change it?
    Best
  • 6.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 20, 2023 02:41 AM
    Look at the LAG status on the AP or the switch to verify functionality.  If the LACP LAG isn't operating properly, then you'll want to verify the configuration once again on both sides and then open a case with TAC if still not working.
  • 7.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 20, 2023 02:53 AM
    Thanks a lot for your help. this our SW configuration
    and in 2 controller I can Find this
    (MC1) [MDC] #show lacp sys-id
    32768,20:4C:03:03:2D:00
    (MC1) [MDC] #exit
  • 8.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 20, 2023 03:00 AM
    That command is looking at the LACP settings on the Mobility Controller, not the AP.
    'show ap debug lacp <id-option> <id-value>' when run from a controller will show LACP information on supported APs.
  • 9.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 20, 2023 03:14 AM
    This this output of current AP-535:
    (MC2) [MDC] #show ap debug lacp ap-name AP-535-test
    AP LACP Status
    0     0      192.168.96.80  0                0
    0     1      192.168.96.81  0                0
  • 10.  RE: Enable LACP on DUAL port AP-535 in Mobility Master
    Posted Nov 20, 2023 10:33 AM
    That appears to show a functional LAG.
