  • 1.  Enaling both 2,4 and 5GHz radio
    Posted May 03, 2022 11:18 AM
    We use 7210 controleur to drive ap105; ap205 and ap305. JToday only 2,4GHz radio seems to be activated (see attachment).
    What could we do to enable and use 5GHz radio WITH 2,4GHz radio ?
    In default profiles, 5GHz radio is enabled (ceck), but it does not seem to be good.
    BILLOT Emmanuel
  • 2.  RE: Enaling both 2,4 and 5GHz radio
    Posted May 03, 2022 11:21 AM
    Info : ArubaOS 8.6 system
    BILLOT Emmanuel
  • 3.  RE: Enaling both 2,4 and 5GHz radio
    Posted May 03, 2022 02:34 PM
    Here is a screen capture, only 1 radio is on. How could the second radio may be on ?
    BILLOT Emmanuel
  • 4.  RE: Enaling both 2,4 and 5GHz radio
    Posted May 03, 2022 04:47 PM
    I finally found : 5GHz was unchecked in node context, blocking activation in MM context.
    BILLOT Emmanuel
