Aruba Apps
  • 1.  Energy meter connected to Aruba port is getting disabled
    Posted Sep 13, 2021 02:52 AM
    Hello team,
    Every port connected to energy meter is getting disabled , everyday we have to enable it .what will be the cause for this .
    Shivam Ojha
  • 2.  RE: Energy meter connected to Aruba port is getting disabled
    Posted Sep 13, 2021 07:37 AM
    You posted this in the Aruba App forum. What is your issue? What type of energy meter is connected to what type of network equipment? Versions? Configuration?
  • 3.  RE: Energy meter connected to Aruba port is getting disabled
    Posted Sep 13, 2021 07:42 AM
    Port is getting disabled . every day they have to manually enable the port .
    When I run show interface brief the port is working as 10-half duplex .
    Thanks & Regards,
    Shivam ojha
    M:7743901736
    Orbit Techsol India Pvt Ltd.|www.orbitindia.net|
  • 4.  RE: Energy meter connected to Aruba port is getting disabled
    Posted Sep 13, 2021 07:44 AM
    Energy meter connected to 1/17 port I have shared you the logs please see if you can find anything let me know .when the port is in auto mode it's running in 10-half duplex so I manually changed the port speed to 10-half duplex
    Thanks & Regards,
    Shivam ojha
    M:7743901736
  • 5.  RE: Energy meter connected to Aruba port is getting disabled
    Posted Sep 13, 2021 11:29 AM
    I don't see any logs shared. If ports are disabled, the reason is likely in the logs.
    It is really hard to assist without have access to the environment, logs, configuration, equipment type, version information, etc. I would suggest that you reach out to your Aruba partner or Aruba support and have a 'live look' together.
  • 6.  RE: Energy meter connected to Aruba port is getting disabled
    Posted Sep 15, 2021 03:09 AM
    Hello team,
    Please respond
    Thanks & Regards,
    Shivam ojha
    M:7743901736
  • 7.  RE: Energy meter connected to Aruba port is getting disabled
    Posted Sep 15, 2021 03:34 AM
    There is not enough information to respond.
    Please reach out to your Aruba partner or Aruba support and have a 'live look' to your deployment together.
