Hi all,
I am trying to get machine auth to work in the lab with cppm 6.3 and a 620 controller running 6.3.1.1
I can get it to work initially but if the station is disconnected or if I do a "aaa user delete" it fails (user) authentication on the reconnect.
I suspect it works as the initial auth was machine (on OS boot) and it changed to the users credentials when login on to the workstation. Which is the normal for Windows.
Any ideas on if its possible to get it working without changing the default authentication mode to Computer in the 802.1x settings?
A screen shot of my enforcement policy on the service (probably not the best way to do this), the “Certificate:Issuer-DN CONTAINS ClearPass” is to allow EAP-TLS
thanks
Andy
