Network Management
ENTITY-MIB support for Aruba 6000 wireless controller
  • 1.  ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 18, 2018 03:48 AM
    Hi -
    I am trying to model the Aruba 6000 controller in my NMS.  I use the ENTITY-MIB as the source of information  for getting the physical / logical chassis and modules present on the device.
    However , when I try to query the device , I do not get any response.
    I want to know if there is a vendor specific MIB which would give the information similar to  ENTITY-MIB.
    (Aruba6000) #show version
    ArubaOS (MODEL: Aruba6000-US), Version 6.4.4.6
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2016, Aruba Networks, an HP company.
    Compiled on 2016-04-15 at 01:09:38 PDT (build 54633) by p4build
    ROM: System Bootstrap, Version CPBoot 1.1.4.0 (build 16250)
    Built: 2007-09-20 16:14:24
    Built by: p4build@re_client_16250
    Switch uptime is 34 days 8 hours 53 minutes 37 seconds
    Reboot Cause: Power Failure (Intent:cause:register ee:ee:0)
    Supervisor Card
    Processor XLR 732 (revision B2) with 1979M bytes of memory.
    32K bytes of non-volatile configuration memory.
    512M bytes of Supervisor Card System flash (model=CF 512MB).
  • 2.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 18, 2018 12:34 PM
    Do you have the output from another device that I could compare the output of?
    Otherwise I'm guessing you're looking for either one of these mib tables: WLSX-SWITCH-MIB (.1.3.6.1.4.1.14823.2.2.1.1) or WLSX-SYSTEMEXT-MIB (.1.3.6.1.4.1.14823.2.2.1.2)
  • 3.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 18, 2018 12:53 PM
    Hi Rob - O/p of the ENTITY-MIB - 1.3.6.1.2.1.47.1.1.1.1 for a HPE 5100 device
    ***** SNMP QUERY STARTED *****
    1: entPhysicalDescr.1 (SnmpAdminString) HPE [48.50.45 (hex)]
    2: entPhysicalDescr.2 (SnmpAdminString) HPE 5510 24G PoE+ 4SFP+ HI 1-slot Switch JH147A Software Version 7.1.070 [48.50.45.20.35.35.31.30.20.32.34.47.20.50.6F.45.2B.20.34.53.46.50.2B.20.48.49.20.31.2D.73.6C.6F.74.20.53.77.69.74.63.68.20.4A.48.31.34.37.41.20.53.6F.66.74.77.61.72.65.20.56.65.72.73.69.6F.6E.20.37.2E.31.2E.30.37.30 (hex)]
    3: entPhysicalDescr.12 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    4: entPhysicalDescr.13 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    5: entPhysicalDescr.14 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    6: entPhysicalDescr.15 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    7: entPhysicalDescr.16 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    8: entPhysicalDescr.17 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    9: entPhysicalDescr.18 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    10: entPhysicalDescr.19 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    11: entPhysicalDescr.20 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    12: entPhysicalDescr.21 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    13: entPhysicalDescr.22 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    14: entPhysicalDescr.23 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    15: entPhysicalDescr.24 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    16: entPhysicalDescr.25 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    17: entPhysicalDescr.26 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    18: entPhysicalDescr.27 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    19: entPhysicalDescr.28 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    20: entPhysicalDescr.29 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    21: entPhysicalDescr.30 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    22: entPhysicalDescr.31 (SnmpAdminString) CONTAINER LEVEL1 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.31 (hex)]
    23: entPhysicalDescr.212 (SnmpAdminString) MODULE LEVEL1 [4D.4F.44.55.4C.45.20.4C.45.56.45.4C.31 (hex)]
    24: entPhysicalDescr.213 (SnmpAdminString) PSU [50.53.55 (hex)]
    25: entPhysicalDescr.214 (SnmpAdminString) PSU [50.53.55 (hex)]
    26: entPhysicalDescr.216 (SnmpAdminString) FAN UNIT [46.41.4E.20.55.4E.49.54 (hex)]
    27: entPhysicalDescr.217 (SnmpAdminString) FAN UNIT [46.41.4E.20.55.4E.49.54 (hex)]
    28: entPhysicalDescr.220 (SnmpAdminString) SENSOR [53.45.4E.53.4F.52 (hex)]
    29: entPhysicalDescr.221 (SnmpAdminString) SENSOR [53.45.4E.53.4F.52 (hex)]
    30: entPhysicalDescr.412 (SnmpAdminString) CONTAINER LEVEL2 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.32 (hex)]
    31: entPhysicalDescr.413 (SnmpAdminString) CONTAINER LEVEL2 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.32 (hex)]
    32: entPhysicalDescr.414 (SnmpAdminString) CONTAINER LEVEL2 [43.4F.4E.54.41.49.4E.45.52.20.4C.45.56.45.4C.32 (hex)]
    33: entPhysicalDescr.442 (SnmpAdminString) MODULE LEVEL2 [4D.4F.44.55.4C.45.20.4C.45.56.45.4C.32 (hex)]
    34: entPhysicalDescr.472 (SnmpAdminString) GigabitEthernet1/0/1 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31 (hex)]
    35: entPhysicalDescr.473 (SnmpAdminString) GigabitEthernet1/0/2 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32 (hex)]
    36: entPhysicalDescr.474 (SnmpAdminString) GigabitEthernet1/0/3 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.33 (hex)]
    37: entPhysicalDescr.475 (SnmpAdminString) GigabitEthernet1/0/4 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.34 (hex)]
    38: entPhysicalDescr.476 (SnmpAdminString) GigabitEthernet1/0/5 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.35 (hex)]
    39: entPhysicalDescr.477 (SnmpAdminString) GigabitEthernet1/0/6 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.36 (hex)]
    40: entPhysicalDescr.478 (SnmpAdminString) GigabitEthernet1/0/7 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.37 (hex)]
    41: entPhysicalDescr.479 (SnmpAdminString) GigabitEthernet1/0/8 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.38 (hex)]
    42: entPhysicalDescr.480 (SnmpAdminString) GigabitEthernet1/0/9 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.39 (hex)]
    43: entPhysicalDescr.481 (SnmpAdminString) GigabitEthernet1/0/10 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.30 (hex)]
    44: entPhysicalDescr.482 (SnmpAdminString) GigabitEthernet1/0/11 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.31 (hex)]
    45: entPhysicalDescr.483 (SnmpAdminString) GigabitEthernet1/0/12 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.32 (hex)]
    46: entPhysicalDescr.484 (SnmpAdminString) GigabitEthernet1/0/13 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.33 (hex)]
    47: entPhysicalDescr.485 (SnmpAdminString) GigabitEthernet1/0/14 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.34 (hex)]
    48: entPhysicalDescr.486 (SnmpAdminString) GigabitEthernet1/0/15 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.35 (hex)]
    49: entPhysicalDescr.487 (SnmpAdminString) GigabitEthernet1/0/16 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.36 (hex)]
    50: entPhysicalDescr.488 (SnmpAdminString) GigabitEthernet1/0/17 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.37 (hex)]
    51: entPhysicalDescr.489 (SnmpAdminString) GigabitEthernet1/0/18 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.38 (hex)]
    52: entPhysicalDescr.490 (SnmpAdminString) GigabitEthernet1/0/19 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.31.39 (hex)]
    53: entPhysicalDescr.491 (SnmpAdminString) GigabitEthernet1/0/20 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.30 (hex)]
    54: entPhysicalDescr.492 (SnmpAdminString) GigabitEthernet1/0/21 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.31 (hex)]
    55: entPhysicalDescr.493 (SnmpAdminString) GigabitEthernet1/0/22 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.32 (hex)]
    56: entPhysicalDescr.494 (SnmpAdminString) GigabitEthernet1/0/23 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.33 (hex)]
    57: entPhysicalDescr.495 (SnmpAdminString) GigabitEthernet1/0/24 [47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.34 (hex)]
    58: entPhysicalDescr.496 (SnmpAdminString) Ten-GigabitEthernet1/0/25 [54.65.6E.2D.47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.35 (hex)]
    59: entPhysicalDescr.497 (SnmpAdminString) Ten-GigabitEthernet1/0/26 [54.65.6E.2D.47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.36 (hex)]
    60: entPhysicalDescr.498 (SnmpAdminString) Ten-GigabitEthernet1/0/27 [54.65.6E.2D.47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.37 (hex)]
    61: entPhysicalDescr.499 (SnmpAdminString) Ten-GigabitEthernet1/0/28 [54.65.6E.2D.47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.31.2F.30.2F.32.38 (hex)]
    62: entPhysicalDescr.500 (SnmpAdminString) M-GigabitEthernet0/0/0 [4D.2D.47.69.67.61.62.69.74.45.74.68.65.72.6E.65.74.30.2F.30.2F.30 (hex)]
    63: entPhysicalVendorType.1 (AutonomousType) (null-oid) zeroDotZero
    64: entPhysicalVendorType.2 (AutonomousType) enterprises.25506.11.1.217
    65: entPhysicalVendorType.12 (AutonomousType) (null-oid) zeroDotZero
    66: entPhysicalVendorType.13 (AutonomousType) (null-oid) zeroDotZero
    67: entPhysicalVendorType.14 (AutonomousType) (null-oid) zeroDotZero
    68: entPhysicalVendorType.15 (AutonomousType) (null-oid) zeroDotZero
    69: entPhysicalVendorType.16 (AutonomousType) (null-oid) zeroDotZero
    70: entPhysicalVendorType.17 (AutonomousType) (null-oid) zeroDotZero
    71: entPhysicalVendorType.18 (AutonomousType) (null-oid) zeroDotZero
    72: entPhysicalVendorType.19 (AutonomousType) (null-oid) zeroDotZero
    73: entPhysicalVendorType.20 (AutonomousType) (null-oid) zeroDotZero
    74: entPhysicalVendorType.21 (AutonomousType) (null-oid) zeroDotZero
    75: entPhysicalVendorType.22 (AutonomousType) (null-oid) zeroDotZero
    76: entPhysicalVendorType.23 (AutonomousType) (null-oid) zeroDotZero
    77: entPhysicalVendorType.24 (AutonomousType) (null-oid) zeroDotZero
    78: entPhysicalVendorType.25 (AutonomousType) (null-oid) zeroDotZero
    79: entPhysicalVendorType.26 (AutonomousType) (null-oid) zeroDotZero
    80: entPhysicalVendorType.27 (AutonomousType) (null-oid) zeroDotZero
    81: entPhysicalVendorType.28 (AutonomousType) (null-oid) zeroDotZero
    82: entPhysicalVendorType.29 (AutonomousType) (null-oid) zeroDotZero
    83: entPhysicalVendorType.30 (AutonomousType) (null-oid) zeroDotZero
    84: entPhysicalVendorType.31 (AutonomousType) (null-oid) zeroDotZero
    85: entPhysicalVendorType.212 (AutonomousType) (null-oid) zeroDotZero
    86: entPhysicalVendorType.213 (AutonomousType) enterprises.25506.11.2.3.126.10.3.1.6.2
    87: entPhysicalVendorType.214 (AutonomousType) enterprises.25506.11.2.3.126.10.3.1.6.2
    88: entPhysicalVendorType.216 (AutonomousType) (null-oid) zeroDotZero
    89: entPhysicalVendorType.217 (AutonomousType) (null-oid) zeroDotZero
    90: entPhysicalVendorType.220 (AutonomousType) (null-oid) zeroDotZero
    91: entPhysicalVendorType.221 (AutonomousType) (null-oid) zeroDotZero
    92: entPhysicalVendorType.412 (AutonomousType) (null-oid) zeroDotZero
    93: entPhysicalVendorType.413 (AutonomousType) (null-oid) zeroDotZero
    94: entPhysicalVendorType.414 (AutonomousType) (null-oid) zeroDotZero
    95: entPhysicalVendorType.442 (AutonomousType) (null-oid) zeroDotZero
    96: entPhysicalVendorType.472 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    97: entPhysicalVendorType.473 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    98: entPhysicalVendorType.474 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    99: entPhysicalVendorType.475 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    100: entPhysicalVendorType.476 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    101: entPhysicalVendorType.477 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    102: entPhysicalVendorType.478 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    103: entPhysicalVendorType.479 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    104: entPhysicalVendorType.480 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    105: entPhysicalVendorType.481 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    106: entPhysicalVendorType.482 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    107: entPhysicalVendorType.483 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    108: entPhysicalVendorType.484 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    109: entPhysicalVendorType.485 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    110: entPhysicalVendorType.486 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    111: entPhysicalVendorType.487 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    112: entPhysicalVendorType.488 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    113: entPhysicalVendorType.489 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    114: entPhysicalVendorType.490 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    115: entPhysicalVendorType.491 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    116: entPhysicalVendorType.492 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    117: entPhysicalVendorType.493 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    118: entPhysicalVendorType.494 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    119: entPhysicalVendorType.495 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    120: entPhysicalVendorType.496 (AutonomousType) enterprises.25506.11.3.1.10.4.191
    121: entPhysicalVendorType.497 (AutonomousType) enterprises.25506.11.3.1.10.4.191
    122: entPhysicalVendorType.498 (AutonomousType) enterprises.25506.11.3.1.10.4.191
    123: entPhysicalVendorType.499 (AutonomousType) enterprises.25506.11.3.1.10.4.191
    124: entPhysicalVendorType.500 (AutonomousType) enterprises.25506.11.3.1.10.4.43
    125: entPhysicalContainedIn.1 (INTEGER) 0
    126: entPhysicalContainedIn.2 (INTEGER) 1
    127: entPhysicalContainedIn.12 (INTEGER) 2
    128: entPhysicalContainedIn.13 (INTEGER) 2
    129: entPhysicalContainedIn.14 (INTEGER) 2
    130: entPhysicalContainedIn.15 (INTEGER) 2
    131: entPhysicalContainedIn.16 (INTEGER) 2
    132: entPhysicalContainedIn.17 (INTEGER) 2
    133: entPhysicalContainedIn.18 (INTEGER) 2
    134: entPhysicalContainedIn.19 (INTEGER) 2
    135: entPhysicalContainedIn.20 (INTEGER) 2
    136: entPhysicalContainedIn.21 (INTEGER) 2
    137: entPhysicalContainedIn.22 (INTEGER) 2
    138: entPhysicalContainedIn.23 (INTEGER) 2
    139: entPhysicalContainedIn.24 (INTEGER) 2
    140: entPhysicalContainedIn.25 (INTEGER) 2
    141: entPhysicalContainedIn.26 (INTEGER) 2
    142: entPhysicalContainedIn.27 (INTEGER) 2
    143: entPhysicalContainedIn.28 (INTEGER) 2
    144: entPhysicalContainedIn.29 (INTEGER) 2
    145: entPhysicalContainedIn.30 (INTEGER) 2
    146: entPhysicalContainedIn.31 (INTEGER) 2
    147: entPhysicalContainedIn.212 (INTEGER) 12
    148: entPhysicalContainedIn.213 (INTEGER) 13
    149: entPhysicalContainedIn.214 (INTEGER) 14
    150: entPhysicalContainedIn.216 (INTEGER) 16
    151: entPhysicalContainedIn.217 (INTEGER) 17
    152: entPhysicalContainedIn.220 (INTEGER) 20
    153: entPhysicalContainedIn.221 (INTEGER) 21
    154: entPhysicalContainedIn.412 (INTEGER) 212
    155: entPhysicalContainedIn.413 (INTEGER) 212
    156: entPhysicalContainedIn.414 (INTEGER) 212
    157: entPhysicalContainedIn.442 (INTEGER) 412
    158: entPhysicalContainedIn.472 (INTEGER) 442
    159: entPhysicalContainedIn.473 (INTEGER) 442
    160: entPhysicalContainedIn.474 (INTEGER) 442
    161: entPhysicalContainedIn.475 (INTEGER) 442
    162: entPhysicalContainedIn.476 (INTEGER) 442
    163: entPhysicalContainedIn.477 (INTEGER) 442
    164: entPhysicalContainedIn.478 (INTEGER) 442
    165: entPhysicalContainedIn.479 (INTEGER) 442
    166: entPhysicalContainedIn.480 (INTEGER) 442
    167: entPhysicalContainedIn.481 (INTEGER) 442
    168: entPhysicalContainedIn.482 (INTEGER) 442
    169: entPhysicalContainedIn.483 (INTEGER) 442
    170: entPhysicalContainedIn.484 (INTEGER) 442
    171: entPhysicalContainedIn.485 (INTEGER) 442
    172: entPhysicalContainedIn.486 (INTEGER) 442
    173: entPhysicalContainedIn.487 (INTEGER) 442
    174: entPhysicalContainedIn.488 (INTEGER) 442
    175: entPhysicalContainedIn.489 (INTEGER) 442
    176: entPhysicalContainedIn.490 (INTEGER) 442
    177: entPhysicalContainedIn.491 (INTEGER) 442
    178: entPhysicalContainedIn.492 (INTEGER) 442
    179: entPhysicalContainedIn.493 (INTEGER) 442
    180: entPhysicalContainedIn.494 (INTEGER) 442
    181: entPhysicalContainedIn.495 (INTEGER) 442
  • 4.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 18, 2018 12:57 PM
    Hi -
    Can you please provide the WLSX-SWITCH-MIB file .
    Want to compile and query the result from the MIB browser.
    Udaya
  • 5.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 19, 2018 06:24 AM
    Aruba dont support it as of today
  • 6.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 19, 2018 11:01 AM
    Hi Praveen -
    >From 7.4 user guide , I see reference to ENTITY-MIB in the user guide ( refer snapshot )
    However , I run 6.4.4.6 on my device ( However , 6.4 user guide does not have reference ).
    Want to know if an equivalent is available in 6.4 version.
    udaya
  • 7.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 19, 2018 08:18 PM
    I'm not seeing the snapshots you're referring to.  Also, there's no ArubaOS firmware 7.4, so I'm suspecting you're referring to some HPE switch documentation.  It's possible that ENTITY-MIB was supported by HPE switches, but not the Aruba controllers since the merger was fairly recent.  You might try using a MIB crawling tool on the Aruba 6000 (since I don't have that model in my home lab) to see which of the MIB tables maps out better.  I was trying to reverse engineer it from the AirWave code, but I was guestimating at the MIBs based on their filenames.  I actually did try walking the MIBs I suggested, but the WSLX-SWITCH-MIB ironically is about the APs/BSSIDs/ESSIDs/usage counters - yay to whoever named that MIB.  The WLSX-SYSTEMEXT-MIB showed a bit more.
    .1.3.6.1.4.1.14823.2.2.1.2.1.1.0 = IpAddress: 100.100.130.30
    .1.3.6.1.4.1.14823.2.2.1.2.1.2.0 = STRING: Aruba7210test
    .1.3.6.1.4.1.14823.2.2.1.2.1.3.0 = STRING: A7210-US
    .1.3.6.1.4.1.14823.2.2.1.2.1.4.0 = INTEGER: master(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.5.0 = IpAddress: 0.0.0.0
    .1.3.6.1.4.1.14823.2.2.1.2.1.6.0 = STRING: 2018-04-19 15:30:07
    .1.3.6.1.4.1.14823.2.2.1.2.1.7.0 = STRING: 0:1:1c:1:1b:32
    .1.3.6.1.4.1.14823.2.2.1.2.1.8.0 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.9.0 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.10.0 = STRING: 27.00 degrees Celsius (NORMAL)
    .1.3.6.1.4.1.14823.2.2.1.2.1.11.0 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.12.0 = INTEGER: 2
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.1 = STRING: Supervisor Card CPU
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.8 = STRING: Network Processor CPU8
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.9 = STRING: Network Processor CPU9
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.10 = STRING: Network Processor CPU10
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.11 = STRING: Network Processor CPU11
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.12 = STRING: Network Processor CPU12
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.13 = STRING: Network Processor CPU13
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.14 = STRING: Network Processor CPU14
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.2.15 = STRING: Network Processor CPU15
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.1 = INTEGER: 3
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.8 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.9 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.10 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.11 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.12 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.13 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.14 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.13.1.3.15 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.2.1 = INTEGER: ram(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.2.2 = INTEGER: flashMemory(2)
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.2.3 = INTEGER: flashMemory(2)
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.3.1 = INTEGER: 2048
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.3.2 = INTEGER: 1535
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.3.3 = INTEGER: 5713
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.4.1 = INTEGER: 22
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.4.2 = INTEGER: 153
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.4.3 = INTEGER: 139
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.5.1 = STRING: /tmp
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.5.2 = STRING: /flash
    .1.3.6.1.4.1.14823.2.2.1.2.1.14.1.5.3 = STRING: /flash1
    .1.3.6.1.4.1.14823.2.2.1.2.1.15.1.2.1 = INTEGER: 5170880
    .1.3.6.1.4.1.14823.2.2.1.2.1.15.1.3.1 = INTEGER: 1849408
    .1.3.6.1.4.1.14823.2.2.1.2.1.15.1.4.1 = INTEGER: 3321472
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.2.1 = INTEGER: sw7210(17)
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.3.1 = INTEGER: 6
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.4.1 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.5.1 = INTEGER: 6
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.6.1 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.7.1 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.8.1 = STRING: Date:05/22/15
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.9.1 = STRING: Rev:06.00
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.10.1 = STRING: (Rev: 1.4)
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.11.1 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.12.1 = INTEGER: active(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.13.1 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.16.1.14.1 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.17.1.2.0 = INTEGER: active(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.17.1.2.1 = INTEGER: active(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.17.1.2.2 = INTEGER: active(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.17.1.2.3 = INTEGER: active(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.18.1.2.0 = INTEGER: inactive(2)
    .1.3.6.1.4.1.14823.2.2.1.2.1.18.1.2.1 = INTEGER: active(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.19.1.2.10.51.3.190 = INTEGER: master(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.19.1.3.10.51.3.190 = STRING: Building1.floor1
    .1.3.6.1.4.1.14823.2.2.1.2.1.19.1.4.10.51.3.190 = STRING: 6.5.1.1_56903
    .1.3.6.1.4.1.14823.2.2.1.2.1.19.1.5.10.51.3.190 = INTEGER: active(1)
    .1.3.6.1.4.1.14823.2.2.1.2.1.19.1.6.10.51.3.190 = STRING: Aruba7210test
    .1.3.6.1.4.1.14823.2.2.1.2.1.19.1.7.10.51.3.190 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.2.1 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.2.2 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.3.1 = STRING: 2016-05-05 23:26:24
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.3.2 = STRING: 2016-05-05 23:26:42
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.4.1 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.4.2 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.5.1 = STRING: E
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.5.2 = STRING: E
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.6.1 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.20.1.6.2 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.21.0 = INTEGER: 4
    .1.3.6.1.4.1.14823.2.2.1.2.1.22.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.23.0 = INTEGER: 50
    .1.3.6.1.4.1.14823.2.2.1.2.1.24.0 = INTEGER: false(2)
    .1.3.6.1.4.1.14823.2.2.1.2.1.25.0 = STRING: User reboot
    .1.3.6.1.4.1.14823.2.2.1.2.1.26.0 = Timeticks: (0) 0:00:00.00
    .1.3.6.1.4.1.14823.2.2.1.2.1.27.0 = STRING: A1.0
    .1.3.6.1.4.1.14823.2.2.1.2.1.28.0 = STRING: 6.5.1.1
    .1.3.6.1.4.1.14823.2.2.1.2.1.29.0 = STRING:
    .1.3.6.1.4.1.14823.2.2.1.2.1.30.0 = Gauge32: 4
    .1.3.6.1.4.1.14823.2.2.1.2.1.31.0 = Gauge32: 35
    .1.3.6.1.4.1.14823.2.2.1.2.1.32.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.1.33.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.2.1.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.2.2.0 = INTEGER: 158
    .1.3.6.1.4.1.14823.2.2.1.2.2.3.0 = INTEGER: 7012
    .1.3.6.1.4.1.14823.2.2.1.2.2.4.0 = INTEGER: 12
    .1.3.6.1.4.1.14823.2.2.1.2.2.5.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.2.6.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.2.7.0 = INTEGER: 2
    .1.3.6.1.4.1.14823.2.2.1.2.2.8.0 = INTEGER: 9
    .1.3.6.1.4.1.14823.2.2.1.2.2.9.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.2.10.0 = INTEGER: 0
    .1.3.6.1.4.1.14823.2.2.1.2.2.11.0 = INTEGER: 0
    Keep in mind, my output is from a 7210 controller which isn't a chassis, so it might work for your needs, but if this isn't what you're looking for, it may be worth it to open a TAC case to inquire.  And like Praveen said - it'd be a feature request to get ArubaOS to adopt the ENTITY-MIB model which you could file at the same time if you contact TAC.
  • 8.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 19, 2018 10:55 PM
    I have attached the pdf file to the case ( refer page 422 of the guide ) which talks about ENTITY-MIB.
    Also, can you please provide details of how to use the MIB Crawling tool mentioned in your earlier post.
    Attachment(s)
    pdf
    ArubaOS 7.4 User Guide.pdf   4.08 MB 1 version
  • 9.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 20, 2018 01:23 AM
    Iam interested in the following details from the ENTITY-MIB
    supervisor , power supply , FAN , Line cards serial numbers
    (Aruba6000) #show inventory
    Supervisor Card slot : 0
    Mobility Processor : FPGA Rev 0x13021320
    Mobility Processor Assembly# : 2010027B
    Mobility Processor Serial# : F00703416
    SC Assembly# : 2010026C (Rev:06.03)
    SC Serial# : F00703414 (Date:01/18/08)
    SC Model# : Aruba6000-US
    Mgmt Port HW MAC Addr : 00:0B:86:61:01:28
    HW MAC Addr : 00:0B:86:0A:03:00 to 00:0B:86:0A:03:7F
    XPLD Version : (Rev: 20)
    PEER Supervisor Card : Absent
    Line Card 0 : Not accessible from this SC
    Line Card 1 : Absent
    Line Card 2 : Absent
    Line Card 3 : Absent
    FAN 0 : OK, Speed High
    FAN 1 : OK, Speed High
    FAN 2 : OK, Speed High
    Fan Tray Assembly# : 2010007C (Rev:01.00)
    Fan Tray Serial# : F02081813 (Date:08/16/11)
    Back Plane Assembly# : 2010006B (Rev:02.06)
    Back Plane Serial# : A00006020 (Date:01/14/08)
    Power Supply type : Power One (400W)
    Power Supply 0 : OK (400W)
    Power Supply 1 : OK (400W)
    Power Supply 2 : Absent
    M3mk1 Card Temperatures : M3mk1 card 38 C
    : CPU 57 C
    AMP Card Temperatures : Processor Card 33 C
    : Mobility Processor 49 C
    : M3mk1 CPU Fan Speed 6490 RPMs
    M3mk1 Card Voltages : M3mk1 5000mV 4980 mV
    : M3mk1 3300mV 3360 mV
    : M3mk1 2500mV 2508 mV
    : M3mk1 1800mV 1780 mV
    : M3mk1 1500mV 1490 mV
    : M3mk1 1250mV 1260 mV
    : M3mk1 1200mV 1200 mV
    : M3mk1 IBC 12000mV 11730 mV
    : M3mk1 CPU CORE 1200mV 1200 mV
    : M3mk1 XGMII VTT 750mV 750 mV
    : M3mk1 VTT0(a&b) 900mV 890 mV
    : M3mk1 VTT1(c&d) 900mV 890 mV
    : AMP 3300mV 3320 mV
    : AMP 2500mV 2500 mV
    : AMP 1800mV 1800 mV
    : AMP 1500mV 1500 mV
    : AMP BCM 1200mV 1180 mV
    : AMP FPGA 1200mV(1) 1200 mV
    : AMP FPGA 1200mV(2) 1200 mV
  • 10.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 20, 2018 09:43 AM
    I see, the switch OS for the sXXXX line is different from the controller OS - the fact it was called AOS as well is confusing - but I think of it as MAS-OS (Mobility Access Switch), vs AOS which I've always alligned with the controllers and APs.  The 6000 chassis is based on the controller OS.  The controller OS doesn't pass that information over SNMP, but there's a few alarm traps for if the fan or power supply stop working.
    Try googling 'SNMP MIB tool' or 'SNMP MIB browser', there's a few free ones out there - though be careful of spyware (I haven't found one that I trust on my system - so I have it installed in a VM instance in case I need to purge it, the Solarwinds one seems promising though).  I looked at the MIB output and didn't see anything that matched the inventory output that you're looking for, seems that CLI cmd is the only place for that data.
  • 11.  RE: ENTITY-MIB support for Aruba 6000 wireless controller
    Posted Apr 20, 2018 10:36 AM
    Thanks Rob,
    I was not aware of the difference in implementation between controller and switches.
    I shall fall back on the "show inventory" CLI to model the attributes.
    Thankks
    udaya
