Network Management
Entity sensor MIB Cisco in IMC
  • 1.  Entity sensor MIB Cisco in IMC
    Posted Jul 19, 2021 10:43 AM
    Hi, I would like to monitor the temperature of my Cisco 4431.
    I add the MIB entity sensor on IMC, I add the custom index then during the test the results of the index propose several instances. I would like to be able to display in the Ressource,  device view tab only some instance (celsisus) and not all the mib.
    I can stop the other probes from monitoring but it's not very nice
    the oid is  1.3.6.1.4.1.9.9.91.1.1.1.1.4 and they return data of type, rpm fan, Mv cpu, Watts, and celsius.
  • 2.  RE: Entity sensor MIB Cisco in IMC
    Posted Jul 20, 2021 04:52 AM
    Hello there,
    In resource - performance option- display index is where you configure , which monitors to desplay on Resource-device page. However there is no option to delete only  some  of the entity tempreture sensors . I got same result as you with a Comware switch,.
    Of course oyu can choose which sensors to start or stop monitor.
    Kind regards,
