Hi, I would like to monitor the temperature of my Cisco 4431.
I add the MIB entity sensor on IMC, I add the custom index then during the test the results of the index propose several instances. I would like to be able to display in the Ressource, device view tab only some instance (celsisus) and not all the mib.
I can stop the other probes from monitoring but it's not very nice
the oid is 1.3.6.1.4.1.9.9.91.1.1.1.1.4 and they return data of type, rpm fan, Mv cpu, Watts, and celsius.
