  • 1.  EntraID device lookup with TEAP
    Posted Jul 18, 2024 06:18 AM
    Hi guys,
    I'm currently facing an issue using TEAP with certificates with EntraID autorization lookups.
    To keep it short, when TEAP Phase 1 and 2 are successful, I need to retrieve the user AND device AD groups for my autorization policies. I don't have any problem with the user but I can't do it with the device as the TEAP-Phase-1-Username is truncated in the computed attributes (like sAMAccountName format: 15 characters + $ and there is not sAMAccountName equivalent in EntraID) and I can't use the certificates fields, either CN or SAN, because when Phase 2 is successful, the attributes contains only the user's certificate values.
    When only phase 1 is successful, I can successfully retrieve the device's EntraID values and groups using the device certificate CN.
    Therefore, I don't have any attributes (which I know) I can rely on to do the EntraID lookups for the device when Phase 1 & 2 are successful.
    Have you faced a similar issue using TEAP-TLS with EntraID ? Is there any attributes I can match between Entra ID and ClearPass to retrieve a device ?
  • 2.  RE: EntraID device lookup with TEAP
    Posted Jul 18, 2024 07:53 AM
    If you use Intune to enroll your certificates, you can easily add the Entra ID device id (or other field/attribute to select the device on) in the user certificate and have it available for lookup. That's what I have done.. and works.
  • 3.  RE: EntraID device lookup with TEAP
    Posted Jul 25, 2024 07:15 AM
    Hi Herman,
    I am trying to configure the EAP-TLS with EntraID as authorization source.
    If i choose entra ID as type under auth source i see only user group query attributes. Could you please post the filter query for device with attributes and sample role mapping/enforcement.
    KK
  • 4.  RE: EntraID device lookup with TEAP
    Posted Jul 30, 2024 04:33 AM
    Here is my device query:
    ... where I query based on the AAD_DeviceID, which I store in the Subject Location (Subject-L) field in the certificate:
    device:devices?$select=id,deviceId,displayName,approximateLastSignInDateTime,enrollmentType&$filter=deviceId eq %{Certificate:Subject-L};deviceGroups:devices/%{device:id}/memberOf?$select=displayName
    The example in the documentation used the displayName to lookup the device instead of the deviceId. Any available identifier would work, and what helped me a lot is to use Postman to test the Graph API queries to find the available attributes (also to be used as filter) and the exact internal/API names of those which don't always match up with what is displayed in the Entra ID web interface.
