Original Message:
Sent: Jan 03, 2025 08:47 AM
Subject: Erreurs giants sur interconnexion lag
la MTU est bien à 9000 sur les interfaces ?
PowerArubaCL: Powershell Module to use Aruba Central
ACEP / ACMX #107 / ACDX #1281
Original Message:
Sent: Jan 02, 2025 03:02 AM
Salut,
Les types de paquets sont essentiellement des paquets avec comme information "TCP previous segment not captured" provenant des serveurs.
Sur les switches voici ce que j'ai en faisant un show
Dans les logs :
2025-01-02T08:34:29.715764+01:00 SWITCH fault-monitord[3671668]: Event|11101|LOG_WARN|CDTR|1|Interface 2/1/51: excessive-oversize-packets fault detected
2025-01-02T08:34:29.708329+01:00 SWITCH fault-monitord[3671668]: Event|11101|LOG_WARN|CDTR|1|Interface 1/1/51: excessive-oversize-packets fault detected
2025-01-02T08:19:30.549720+01:00 SWITCH fault-monitord[3671668]: Event|11101|LOG_WARN|CDTR|1|Interface 2/1/51: excessive-oversize-packets fault detected
2025-01-02T08:19:30.543183+01:00 SWITCH fault-monitord[3671668]: Event|11101|LOG_WARN|CDTR|1|Interface 1/1/51: excessive-oversize-packets fault detected
2025-01-02T08:04:30.724333+01:00 SWITCH fault-monitord[3671668]: Event|11101|LOG_WARN|CDTR|1|Interface 2/1/51: excessive-oversize-packets fault detected
2025-01-02T08:04:30.716743+01:00 SWITCH fault-monitord[3671668]: Event|11101|LOG_WARN|CDTR|1|Interface 1/1/51: excessive-oversize-packets fault detected
Sur l'interface lag :
Admin state is up
Description :
MAC Address : 4c:d5:87:50:bc:c0
Aggregated-interfaces : 1/1/51 2/1/51
Aggregation-key : 10
Aggregate mode : active
Speed : 20000 Mb/s
qos trust dscp
VLAN Mode: native-untagged
Native VLAN: 1
Allowed VLAN List: X,Y
L3 Counters: Rx Disabled, Tx Disabled
Statistic RX TX Total
Packets 486137929 17076725 503214654
Unicast 38795905 13630098 52426003
Multicast 98239909 3375581 101615490
Broadcast 349102115 71046 349173161
Bytes 79288088889 1769664085 81057752974
Jumbos 949687 756 950443
Dropped 0 0 0
Pause Frames 0 0 0
Errors 547930 0 547930
CRC/FCS 0 n/a 0
Collision n/a 0 0
Runts 0 n/a 0
Giants 547930 n/a 547930
Original Message:
Sent: Dec 31, 2024 08:25 AM
c'était quoi comme type de paquet ?
tu as quoi dans les show de ton 6300 ?
Original Message:
Sent: Dec 31, 2024 07:49 AM
En effet, je ne pense pas que cela viennent des bornes WiFi, car nous utilisons un contrôleur.
J'ai un switch d'accès 6300 sur lequel j'ai connecté le pc de monitoring avec Wireshark. Ce switch est interconnecté à deux switches cœurs par le lag en question.
Lors des captures wireshark, j'ai configuré un port mirror qui capture les paquets entrants et sortants de l'interface lag.
Après analyse des trames, je n'ai pas eu de paquets dépassant énormément le MTU (1509~1518).
Original Message:
Sent: Dec 31, 2024 04:30 AM
Ca peut etre un autre équipement que des bornes WiFi
Ca donne quoi ta capture de paquet ? quand tu regarde la taille des trames ? rien superieur à 1500 ? tu fais ta capture ou ?
Original Message:
Sent: Dec 31, 2024 04:07 AM
Je te remercie de ta réponse, ce qui est d'autant plus étrange c'est que je n'avais pas ces erreurs giants avant, ils sont apparus d'un coup sachant que j'avais des bornes déjà en production
Original Message:
Sent: Dec 31, 2024 03:35 AM
Il y a des fois des PMTUD check et c'est pour cela les jumbo frames
Original Message:
Sent: Dec 31, 2024 03:29 AM
Bonjour,
Oui, j'ai des bornes WIFI Cisco configurés.
Bien cordialement,
Original Message:
Sent: Dec 30, 2024 11:35 AM
Bonjour,
tu n'aurai pas des bornes WiFi ?
Original Message:
Sent: Dec 30, 2024 03:14 AM
Bonjour,
Je travaille actuellement avec des switches Aruba 6300.
En effet, il y a peu de temps j'ai constaté des erreurs giants sur mon lag configuré, j'ai laissé le MTU par défaut à 1500 puis à 9100 (MTU conseillé par Aruba sur un lag)
J'ai bien sur utilisé Wireshark afin de trouver la source du problème mais rien, je ne capture que des paquets baby giants (1509).
De plus, j'ai réalisé des tests afin de trouver quel VLAN engendré ces erreurs là mais je ne sais comment remonter à la source.
Avez-vous déjà été confrontés à ces problèmes là ?
Merci d'avance de vos réponses !
