Hi.
2023-10-04 12:06:56,790 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_eap_peap: Initiate
2023-10-04 12:06:56,790 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - reqst_update_state: Access-Challenge 47:88:5414f3f79298:ANUAJACpADv73lcBX2eM/3+hlyXkHZieP0S9mg==
2023-10-04 12:06:56,852 [Th 253 Req 22535932 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_service: The request was categorized into service "BX-802.1x-WBAP" - 49:440:5414f3f79298
2023-10-04 12:06:56,853 [Th 253 Req 22535932 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - TLS_accept:error in SSLv3 read client key exchange A
2023-10-04 12:06:56,853 [Th 253 Req 22535932 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - reqst_update_state: Access-Challenge 49:1124:5414f3f79298:ACYAYwCxAAb83lcBd5xebnMGPKZ1CxS+eB99kA==
2023-10-04 12:07:48,876 [main SessId R0013b27c-05-651d3940] ERROR RadiusServer.Radius - reqst_clean_list: Deleting request sessid - R0013b27c-05-651d3940, state - ACYAYwCxAAb83lcBd5xebnMGPKZ1CxS+eB99kA=
2023-10-04 12:07:48,876 [main SessId R0013b27c-05-651d3940] ERROR RadiusServer.Radius - reqst_clean_list: Packet 47:252:88:5414f3f79298 recv 1696414016.785892 - resp 1696414016.790918
2023-10-04 12:07:48,876 [main SessId R0013b27c-05-651d3940] ERROR RadiusServer.Radius - reqst_clean_list: Packet 49:440:1124:5414f3f79298 recv 1696414016.851903 - resp 1696414016.853393
2023-10-04 12:07:48,876 [main SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_policy: Starting Policy Evaluation.
2023-10-04 12:07:48,877 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO Common.EndpointTable - Returning EndpointSPtr for macAddr 5414f3f79298
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO Common.TagDefinitionCacheTable - No InstanceTagDefCacheMap found for instance id = 3265 entity id = 29
The whole logs are here:
Request log details for session: R0013b27c-05-651d3940
Time Message
2023-10-04 12:06:56,786 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_service: Starting Service Categorization - 47:252:5414f3f79298
2023-10-04 12:06:56,788 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260660 h=223 r=R0013b27c-05-651d3940] INFO Core.ServiceReqHandler - Service classification result = BX-802.1x-WBAP
2023-10-04 12:06:56,789 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - Service Categorization time = 3 ms
2023-10-04 12:06:56,789 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_service: The request has been categorized into service "BX-802.1x-WBAP"
2023-10-04 12:06:56,789 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_ldap: searching for user BBBBB-net\XXXXXXX in AD:corp.BBBBB.net
2023-10-04 12:06:56,790 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_ldap: found user BBBBB-net\XXXXXXX in AD:corp.BBBBB.net
2023-10-04 12:06:56,790 [Th 248 Req 22535931 SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - LDAP/AD User lookup time = 1 ms
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO Common.TagDefinitionCacheTable - Building the TagDefMapTable for NAD instance=3265
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO Common.TagDefinitionCacheTable - Built 0 tag(s) for NAD instanceId=3265|entityId=29
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO TAT.TagAttrHolderBuilder - No tags built for instanceId=3265|entity=Device
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO TAT.AluTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL AuthLocalUser)
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO TAT.GuTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL GuestUser)
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=psauto-1690209519-4260800 h=239 r=R0013b27c-05-651d3940] INFO TAT.OnboardTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Onboard Device User)
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_RADIUS Started ***
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskAuthSourceRestriction **
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskRoleMapping **
2023-10-04 12:07:48,878 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskAuthSourceRestriction **
2023-10-04 12:07:48,879 [RequestHandler-1-0x7f19f29f4700 h=28372189 c=R0013b27c-05-651d3940] INFO Core.PETaskRoleMapping - Roles: BX-Role-AD-Lista-OU
2023-10-04 12:07:48,879 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskRoleMapping **
2023-10-04 12:07:48,879 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskPolicyResult **
2023-10-04 12:07:48,880 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372191 c=R0013b27c-05-651d3940] ERROR Core.PETaskPolicyResult - handleHttpResponseEv: All policy result cache lookups failed
2023-10-04 12:07:48,880 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskPolicyResult **
2023-10-04 12:07:48,880 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskEnforcement **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 h=28372192 c=R0013b27c-05-651d3940] INFO Core.PETaskEnforcement - EnfProfiles: Enf-Prof-BX-IAP-Role-AD-OU
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskEnforcement **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskRadiusEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskRadiusCoAEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskAppEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskAgentEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskPostAuthEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskGenericEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 h=28372198 c=R0013b27c-05-651d3940] INFO Core.PETaskGenericEnfProfileBuilder - getApplicableProfiles: No App enforcement (Generic) profiles applicable for this device
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 h=28372193 c=R0013b27c-05-651d3940] INFO Core.PETaskRadiusEnfProfileBuilder - EnfProfileAction=ACCEPT
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 h=28372193 c=R0013b27c-05-651d3940] INFO Core.PETaskRadiusEnfProfileBuilder - Radius enfProfiles used: Enf-Prof-BX-IAP-Role-AD-OU
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 h=28372193 c=R0013b27c-05-651d3940] INFO Core.EnfProfileComputer - getFinalSessionTimeout: sessionTimeout = 0
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskGenericEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskAgentEnfProfileBuilder **
2023-10-04 12:07:48,881 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskAppEnfProfileBuilder **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskCliEnforcement **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 h=28372199 c=R0013b27c-05-651d3940] INFO Core.PETaskCliEnforcement - startHandler: No commands for CLI enforcement
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskRadiusEnfProfileBuilder **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372197 c=R0013b27c-05-651d3940] INFO Core.PETaskPostAuthEnfProfileBuilder - getApplicableProfiles: No Post auth enforcement profiles applicable for this device
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskCliEnforcement **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372194 c=R0013b27c-05-651d3940] INFO Core.PETaskRadiusCoAEnfProfileBuilder - getApplicableProfiles: No radius_coa enforcement profiles applicable for this device
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskPostAuthEnfProfileBuilder **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskRadiusCoAEnfProfileBuilder **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskAuthStatusInfo **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskOutputPolicyRes **
2023-10-04 12:07:48,882 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Starting PETaskSessionLog **
2023-10-04 12:07:48,885 [main SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - Policy Evaluation time = 9 ms
2023-10-04 12:07:48,885 [main SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_policy: Received Accept Enforcement Profile
2023-10-04 12:07:48,885 [main SessId R0013b27c-05-651d3940] INFO RadiusServer.Radius - rlm_policy: Policy Server reply does not contain Posture-Validation-Response
2023-10-04 12:07:48,885 [RequestHandler-1-0x7f19f29f4700 h=28372201 c=R0013b27c-05-651d3940] INFO Core.XpipPolicyResHandler - populateResponseTlv: PETaskPostureOutput does not exist. Skip sending posture VAFs
2023-10-04 12:07:48,885 [RequestHandler-1-0x7f19f29f4700 h=28372201 c=R0013b27c-05-651d3940] INFO Core.PolicyResCollector - getSohr: Failed to generate Sohr
2023-10-04 12:07:48,885 [RequestHandler-1-0x7f19f29f4700 h=28372200 c=R0013b27c-05-651d3940] INFO Core.PolicyResCollector - getSohr: Failed to generate Sohr
2023-10-04 12:07:48,885 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskSessionLog **
2023-10-04 12:07:48,885 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskOutputPolicyRes **
2023-10-04 12:07:48,885 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - ** Completed PETaskAuthStatusInfo **
2023-10-04 12:07:48,885 [RequestHandler-1-0x7f19f29f4700 r=R0013b27c-05-651d3940 h=28372187 c=R0013b27c-05-651d3940] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_RADIUS Completed ***
