Hi
A customer have had issues to install 6.10.8 on a cluster. Aruba TAC couldn't find quick solution to the installation problem, and we had already successfully deployed 6.11 on one of the test clusters.
Thus we took the descision on install ClearPass 6.11 on the cluster having the issue to install 6.10.8.
One of the two nodes in the cluster could install 6.11 without any issues.
The other one got error messages right after selecting install image, C1000.
After contact with Aruba TAC they concluded that there must be some hardware fault and initiated an RMA. Today the new hardware have arrived and we get the exact same error message on the new hardware.
The same USB stick that was working on one sevrer have been utilized for the installation, but just to be sure the stick isn't corrupt the installation has also been tested with another stick.
I will continue to work with TAC in this case but would like to know if anyone else have experinced similar issues during installation of ClearPass 6.11?
This specific hardware was replaced in February last year after a hardware failure. The three C1000 servers we have successfully installed 6.11 on have all been several years old.
Is there any hardware diffrences on the C1000/CP-HW-500 delivered today comparred to hardware delivered several years back?
Best Regards
Jonas Hammarbäck
MVP 2023, ACCX #1335, ACMP, ACDP, ACP-Network Security, ACEP, ACSA
Aranya AB
