  • 1.  Error in establishing TLS session while using 802.1X Authentication
    Posted Nov 11, 2014 11:54 PM
    Dear concerned,
    I am getting error while using 802.1X authentication. However i have configured all the prerequisites properly. Please find the attached snapshots.
  • 2.  RE: Error in establishing TLS session while using 802.1X Authentication
    Posted Nov 11, 2014 11:58 PM
    The error that you are seeing is that the client does not have CPPMs cert in its trust list.
  • 3.  RE: Error in establishing TLS session while using 802.1X Authentication
    Posted Nov 12, 2014 12:05 AM
    From where i would get this certificate ? and how can i import this to user end ?
  • 4.  RE: Error in establishing TLS session while using 802.1X Authentication
    Posted Nov 12, 2014 12:12 AM
    Your windows client should have prompted you to accept the cert the first time if not you will need to manually configure the client. There are plenty of results if you Google PEAP and windows 7.
    http://msdn.microsoft.com/en-us/library/dd759219.aspx
    You need to export the CPPM radius cert from the Administration » Certificates » Server Certificate
    and import it into the client.
  • 5.  RE: Error in establishing TLS session while using 802.1X Authentication
    Posted Nov 12, 2014 12:22 AM
    Thankyou dear tarnold.
    Thumbs up.
