Network Management
  • 1.  Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 24, 2021 03:05 AM
    we have updatet the IMC from 7.3 E0405 to IMC 7.3 E0705P12. We have no Error at the Update. After reboot the Server an start the out error the new version of the IMC. We connect to the Imc with the latest Chrome to the IMC we became an error on the Alert Sound Page an the IMC play no Sounds when we recieve an error or an Trab.
    We found two Errors in the Logs.
    2021-08-23 13:15:48 [ERROR] [com.imf.61.0.MessageBroadcaster-3] [com.imc.common.MessageFactoryHelper::messageToASN1]
    com.ibm.asn1.ASN1Exception: Read tag Universal Enumeration but expected Universal OctetString (offset
    at com.ibm.asn1.BERDecoder.throwASN1Exception(BERDecoder.java:26)
    at com.ibm.asn1.BERDecoder.checkNextTag(BERDecoder.java:229)
    at com.ibm.asn1.BERDecoder.decodeOctetString(BERDecoder.java:717)
    at com.imc.asn1msg.qvresource.AsnDeviceInfo.decode(AsnDeviceInfo.java:86)
    at com.imc.common.MessageFactoryHelper.messageToASN1(MessageFactoryHelper.java:285)
    at com.imc.common.MessageCommonHandler.handleMessage(MessageCommonHandler.java:199)
    at com.imc.common.MessageCommonHandler.onMessage(MessageCommonHandler.java:173)
    at com.imf.SafeMessageListener.onMessage(SafeMessageListener.java:94)
    at com.imf.MessageBroadcasterImpl$DispatchTask.run(MessageBroadcasterImpl.java:404)
    at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
    at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
    at java.base/java.lang.Thread.run(Thread.java:834)
    2021-08-23 13:12:18 [INFO ] [http-nio-8080-exec-113] [com.imc.common.ex.ErrorPageBean::checkLoop] countMap add count, curr : 3
    2021-08-23 13:12:18 [INFO ] [http-nio-8080-exec-113] [com.imc.common.ex.ErrorPageBean::checkLoginErrorException] ErrorPageBean find an error.Refresh page once:javax.servlet.forward.request_uri-/fault/applet/faultBoardChart_content.xhtml
    2021-08-23 13:12:18 [ERROR] [http-nio-8080-exec-90] [com.imc.common.ex.ErrorPageBean::checkLoginErrorException] ErrorPageBean find error : java.lang.NullPointerException
    at com.imc.fault.applet.view.FaultBoardConfigBean.loadFaultBoardConfig(FaultBoardConfigBean.java:1132)
    at com.imc.fault.applet.view.FaultBoardConfigBean.<init>(FaultBoardConfigBean.java:531)
    at jdk.internal.reflect.GeneratedConstructorAccessor328.newInstance(Unknown Source)
    at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
    at java.base/java.lang.reflect.Constructor.newInstance(Constructor.java:490)
    at java.base/java.lang.Class.newInstance(Class.java:584)
    at org.apache.myfaces.config.annotation.Tomcat7AnnotationLifecycleProvider.newInstance(Tomcat7AnnotationLifecycleProvider.java:60)
    at org.apache.myfaces.config.ManagedBeanBuilder.buildManagedBean(ManagedBeanBuilder.java:156)
    at org.apache.myfaces.el.unified.resolver.ManagedBeanResolver.createManagedBean(ManagedBeanResolver.java:333)
    at org.apache.myfaces.el.unified.resolver.ManagedBeanResolver.getValue(ManagedBeanResolver.java:296)
    at javax.el.CompositeELResolver.getValue(CompositeELResolver.java:67)
    at org.apache.myfaces.el.unified.resolver.FacesCompositeELResolver.getValue(FacesCompositeELResolver.java:179)
    at org.apache.el.parser.AstIdentifier.getValue(AstIdentifier.java:71)
    at org.apache.el.parser.AstValue.getValue(AstValue.java:161)
    at org.apache.el.ValueExpressionImpl.getValue(ValueExpressionImpl.java:187)
    at org.apache.myfaces.view.facelets.el.ELText$ELTextVariable.writeText(ELText.java:219)
    at org.apache.myfaces.view.facelets.el.ELText$ELTextComposite.writeText(ELText.java:131)
    at org.apache.myfaces.view.facelets.compiler.TextInstruction.write(TextInstruction.java:45)
    at org.apache.myfaces.view.facelets.compiler.UIInstructions.encodeBegin(UIInstructions.java:46)
    at org.apache.myfaces.view.facelets.compiler.UILeaf.encodeAll(UILeaf.java:508)
    at javax.faces.component.UIComponentBase.encodeAll(UIComponentBase.java:541)
    at org.apache.myfaces.view.facelets.FaceletViewDeclarationLanguage.renderView(FaceletViewDeclarationLanguage.java:1981)
    at org.apache.myfaces.application.ViewHandlerImpl.renderView(ViewHandlerImpl.java:305)
    at javax.faces.application.ViewHandlerWrapper.renderView(ViewHandlerWrapper.java:59)
    at org.apache.myfaces.tomahawk.application.ResourceViewHandlerWrapper.renderView(ResourceViewHandlerWrapper.java:169)
    at org.apache.myfaces.lifecycle.RenderResponseExecutor.execute(RenderResponseExecutor.java:116)
    at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:241)
    at javax.faces.webapp.FacesServlet.service(FacesServlet.java:199)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
    at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208)
    at org.primefaces.webapp.filter.FileUploadFilter.doFilter(FileUploadFilter.java:79)
    at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
    at com.imc.servlet.filters.FileUploadEncodingFilter.doFilter(FileUploadEncodingFilter.java:29)
    at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
    at org.apache.catalina.filters.HttpHeaderSecurityFilter.doFilter(HttpHeaderSecurityFilter.java:126)
    at com.imc.filter.ImcBrowserCacheInvalidFilter.doFilter(ImcBrowserCacheInvalidFilter.java:66)
    at com.imc.filter.ImcNoEtagFilter.doFilter(ImcNoEtagFilter.java:47)
    at com.imc.filter.ImcExpiresFilter.doFilter(ImcExpiresFilter.java:830)
    at com.imc.filter.ImcRefererFilter.doFilter(ImcRefererFilter.java:120)
    at com.imc.servlet.filters.UrlAccessController.doFilter(UrlAccessController.java:507)
    at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:219)
    at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
    at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:492)
    at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:165)
    at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
    at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:116)
    at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:452)
    at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1201)
    at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:654)
    at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.doRun(NioEndpoint.java:1782)
    at org.apache.tomcat.util.net.NioEndpoint$SocketProcessor.run(NioEndpoint.java:1741)
    at org.apache.tomcat.util.threads.TaskThread$WrappingRunnable.run(TaskThread.java:61)
    #imc
  • 2.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 24, 2021 04:36 AM
    Hello @DDGadmin ,
    Want to know if all services are 'UP' in IDMA?
    Are you seeing error in Firefox as well?
    Thanks!
  • 3.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 24, 2021 05:55 AM
    hi akg7,
    all Service are UP an running.
    We have used Firefoy, IE11, Edge and old Version of Chrome.
    All Browser have the same Porblem.
  • 4.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 25, 2021 05:20 AM
    Hello @DDGadmin ,
    Is this Linux or Windows server?
    Can you check the http.properties file that which port is configured for http and https?
    \iMC\client\conf\http.properties
    Check ports are matching with your configured ports or not?
    Thanks!
  • 5.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 25, 2021 05:40 AM
    it is an Windows Server 2016 with all patches.
    The Ports in the config are matching.
    her is the Error Page:
    Remediation Suggestion
    1) Go back to Home to try again.
    2) Collect logs and contact technical support for help. To obtain compressed logs, log in to the system server, execute file deploy\logfiles.bat (for Windows) or deploy/logfiles.sh (for Linux) in the installation path, and go to the tmp folder in the installation path.
    Error Details
    at com.h3c.imc.fault.applet.view.FaultBoardConfigBean.loadFaultBoardConfig(FaultBoardConfigBean.java:1132)
    at com.h3c.imc.fault.applet.view.FaultBoardConfigBean.<init>(FaultBoardConfigBean.java:531)
    at jdk.internal.reflect.GeneratedConstructorAccessor303.newInstance(Unknown Source)
    at com.h3c.imc.servlet.filters.FileUploadEncodingFilter.doFilter(FileUploadEncodingFilter.java:29)
    at com.h3c.imc.filter.ImcBrowserCacheInvalidFilter.doFilter(ImcBrowserCacheInvalidFilter.java:66)
    at com.h3c.imc.filter.ImcNoEtagFilter.doFilter(ImcNoEtagFilter.java:47)
    at com.h3c.imc.filter.ImcExpiresFilter.doFilter(ImcExpiresFilter.java:830)
    at com.h3c.imc.filter.ImcRefererFilter.doFilter(ImcRefererFilter.java:120)
    at com.h3c.imc.servlet.filters.UrlAccessController.doFilter(UrlAccessController.java:507)
  • 6.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 25, 2021 05:45 AM
    HTTP Port 8080
    HTTPS Prot 8443
  • 7.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 25, 2021 06:18 AM
    Are you using the same ports for http/https?
    Thanks!
  • 8.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 25, 2021 07:44 AM
    we use for HTTP Port 8080 and tor HTTPS 8443
  • 9.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 26, 2021 03:15 AM
    Hello @DDGadmin ,
    This issue needs LAB intervention, We request you to log a case on HPE Support Center portal for further resolution using the link:
    https://support.hpe.com/hpesc/public/home/
    Thanks!
  • 10.  RE: Error Page on Alert Sound page after update to IMC 7.3 E0705P12
    Posted Aug 26, 2021 04:11 AM
    Hello akg7,
    thanks for the help. We open a case on the Support Center.
