Only interactive login is supported to an Instant AP. You can't run a command. If you want to script commands, using something like expect or paramiko may help, but using a management system or API calls may be better than CLI scraping depending on the application. Not sure if expect/paramiko are available for C++.
If you have urgent issues, always contact your HPE Aruba Networking partner, distributor, or Aruba TAC Support. Check
https://www.arubanetworks.com/support-services/contact-support/ for how to contact HPE Aruba Networking TAC. Any opinions expressed here are solely my own and not necessarily that of Hewlett Packard Enterprise or HPE Aruba Networking.
Original Message:
Sent: Feb 14, 2025 01:41 AM
Subject: [ERROR] Received SSH_MSG_DISCONNECT: 2:Only cli connections are allowed to the AP
Hi All,
wrote a sample application using C++ by using libssh (libssh-0.11.0) , which will create a session and connect to aruba device.
and wanted to execute the CLI commands using the application, the api used ssh_channel_request_exec(channel, cmd)
where the 2nd parameter cmd of the API passing the CLI command, getting the below error,
ERROR:- Received SSH_MSG_DISCONNECT: 2:Only cli connections are allowed to the AP
Thanks in advance!
