Error when creating CSR for wildcard certificate
  • 1.  Error when creating CSR for wildcard certificate
    Posted Dec 19, 2016 08:13 AM
    When creating a Certificate Signing Request for a wildcard certificate (e.g. *.example .com), I receive an error " Common Name supports only some special characters (-, _, .) ".
    although, according to this information: https://www.sslsupportdesk.com/aruba-clearpass-csr-instructions/ it should be possible.
    Any idea how to avoid this error?
  • 2.  RE: Error when creating CSR for wildcard certificate
    Posted Dec 19, 2016 08:51 AM
    You need to create the CSR on an external server like Linux or Windows then you can generate the cert then import the cert & private key into ClearPass.
    Cheers
    James
