Errors on Radius request on Mac-Authentication
  • 1.  Errors on Radius request on Mac-Authentication
    Posted 11 days ago
    hello, I configured Aruba ClearPass on two 2560 poe model switches  but mac-authentication does not work.(other switch work correctly)
     I noticed that the radius request that comes to me from the switch has the Service-Type attribute 2 (framed-user) instead of 10, which is call-check like all the other switches, and so it try to connect used Wired - EAP-TLS Certificate Authentication  instead of Wired - Mac Authentication.
    how can i change the radius request service type attribue for MC auth request?
  • 2.  RE: Errors on Radius request on Mac-Authentication
    Posted 10 days ago
    In your service categorization for the MAC auth you can add Framed-User as a Service-Type and use:
    Then in the 802.1X service use:
    Typical starting point for service categorization of MAC auth on wired, agreed the Framed-User is odd:
    802.1X service:
    Carson Hulcher, ACEX#110
  • 3.  RE: Errors on Radius request on Mac-Authentication
    Posted 10 days ago
    Hi Carson,
    thanks to reply, my clearpass configuration are like the one you reported:
    MAC:
     in 802.1X service i not have client-mac-address NOT_EQUALS, i have only nas port type and service-type radius:IETF
    MAC, are on top of 802.1x ...... at the moment i have Add service type framed-user also at MAC-auth, in this case work correctly.
    When a PC arrives with the certificate it is not in the approved Mac database and therefore fails and switches to the 802.1x service that authorize!
    For Information:
    The switch that have this problem are a J8165A and have the latest update H.10.119
  • 4.  RE: Errors on Radius request on Mac-Authentication
    Posted 10 days ago
    Yeah, that switch is ancient and pre-dates the feature convergence in AOS-S.  Don't expect any kind of feature equivalence with more current switches.
  • 5.  RE: Errors on Radius request on Mac-Authentication
    Posted 10 days ago
    Also, you don't mention what version of software the switch is running, and an example of your configuration would be useful.
