We have configured on an IRF fabric a VLAN for ESXi VMs of specific network.
We want to make Link Aggregation in ESXi (teaming with "Route based on IP Hash") and IRF with 2 IRF ports and 2 vmnic ports.
The VLAN is an isolated VLAN, created only for these physically separate VM transmission, so the traffic is untagged (no trunk or hybrid needed to pass other VLAN, all traffic must be ingres tagged 200 and egres untagged so that it remains in that VLAN internally to the switch, no routing needed fo that VLAN).
The ports used and therefore also the Bridge-Aggregation interface are all configured within the specified VLAN (200).
According to the HP document (pages 15 to 20)
http://h20195.www2.hp.com/v2/GetPDF.aspx%2F4AA4-4192ENW.pdf
we must configure IRF Bridge-Aggregation in trunk mode, the document say that for HP switches, the trunk is the only mode supported for ESXi IP Hash.
My doubt is that trunk mode for HP switches is different than trunk mode for IRF (Comeware).
We tried this:
system-view
interface bridge-aggregation 21
description aggr iface esxi11 dmz
quit
interface GigabitEthernet 1/0/39
port link-aggregation group 21
interface GigabitEthernet 2/0/39
interface Bridge-Aggregation 21
port link-type trunk
port trunk pvid vlan 200
undo port trunk permit vlan 1
undo shutdown
quit
The commands to verify the Link Aggregation on IRF, give me any outcome that seems ok, but with the command:
display link -aggregation summary
I do not see the connection to the peer (Partner ID = none) .
How can I be sure that the Link Aggregation Static is properly established and well funtioning between and point (ESXi - IRF) ?
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, RAGG -- Route-Aggregation
Aggregation Mode: S -- Static, D -- Dynamic
Loadsharing Type: Shar -- Loadsharing, NonS -- Non-Loadsharing
Actor System ID: 0x8000, cc3e-5f40-b089
AGG AGG Partner ID Select Unselect Share
Interface Mode Ports Ports Type
BAGG21 S none 2 0 Shar
BAGG31 S none 2 0 Shar
BAGG101 D 0xffff, 2c44-fd84-8494 4 0 Shar
BAGG102 D 0xffff, 2c44-fd84-6540 4 0 Shar
BAGG103 D 0xffff, 2c44-fd84-9e1c 4 0 Shar
BAGG104 D 0xffff, 2c44-fd84-8648 4 0 Shar
Thank you in advance
#VLAN
