AOS-CX Switch Simulator
EVE-NG ClearPass not starting
This thread has been viewed 71 times
  • 1.  EVE-NG ClearPass not starting
    Posted Feb 10, 2025 04:01 PM
    I am having an issue with EVE-NG and getting ClearPass to work. I just got things setup and I am testing to make sure the nodes work so that I can build out labs for the ACSP exam. I have followed the instructions from EVE-NG and I am able to add the ClearPass node into my topology. When I go to start up the ClearPass server node, it will act like it is turning on but in approximately 1-2 seconds it will shut off and not boot up. I have posed the question on EVEs forums Aruba Clearpass Issue - Support and News Forum as well as talked to their live helpdesk and have not gotten a resolution.
    I have nothing setup as far as lab wise, I am just trying to test the nodes to make sure that they are working. Has anybody else had this issue?
  • 2.  RE: EVE-NG ClearPass not starting
    Posted Feb 11, 2025 03:31 AM
    What QEMU Version of VM you selected? Try with different version.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 3.  RE: EVE-NG ClearPass not starting
    Posted Feb 11, 2025 10:02 AM
    Edited by Russ_Altorfer Feb 11, 2025 02:01 PM
    It looks like I am running 1:6.2. How would I go about updating the version?
  • 4.  RE: EVE-NG ClearPass not starting
    Posted Feb 11, 2025 01:52 PM
    Ok it's very easy.
    On the node you just check QEMU Version dropdovn
    I just checked with V6.0 and it works.
    Another thing to check is if you enable virtualization HW to be exposed to VM? Here is relevant snippet from VMware
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2024
  • 5.  RE: EVE-NG ClearPass not starting
    Posted Feb 11, 2025 02:06 PM
    I changed the QEMU version on the node. It looks like it is working 'fingers crossed'.
  • 6.  RE: EVE-NG ClearPass not starting
    Posted Feb 11, 2025 08:01 PM
    Yes, I'm sure it works for you now. There are times when you have to change that version of qemu so that it can boot the machine, let us know.
    Best Regards
    Daniel Ruiz
    If you have urgent issues, always contact your Aruba partner, distributor, or Aruba TAC Support.
    Check https://www.arubanetworks.com/support-services/contact-support/ for how to contact Aruba TAC.
  • 7.  RE: EVE-NG ClearPass not starting
    Posted Feb 17, 2025 03:48 PM
    It is working for me now. The server will turn on and stay turned on. Unfortunately, my employer will not allow me to download a Linux iso to apply to a node so that I can access and setup the ClearPass server. I will be working on setting up a ClearPass server from our current ESXi server and have it connected to the lab in EVE so that I can work on it that way. If I cannot do that or not allowed to do that, I will have to develop something with our physical testing network.
  • 8.  RE: EVE-NG ClearPass not starting
    Posted Feb 18, 2025 12:54 AM
    Hi.
    You can always connect one Clearpass interface to external network and configure it from your computer.
    Best, Gorazd
    Gorazd Kikelj
    MVP Guru 2025
  • 9.  RE: EVE-NG ClearPass not starting
    Posted Feb 24, 2025 10:22 AM
    I am looking to setup the ClearPass server on our current ESXi environment, so it will be using our current physical environment. Just to cover and get everything I need together; do I need to get another license or anything specific for that server? I do not have access to our ESXi environment so I will be setting this up with my boss and I would like to make sure that I have everything that I would need before I get into the working session.
  • 10.  RE: EVE-NG ClearPass not starting
    Posted Feb 24, 2025 10:44 PM
    When installing Clearpass you would need licenses.
    If it's just for testing purposes, you can have Trial licenses for Clearpass (so the Clearpass Policy Manager Licenses, Access Licenses, OnGuard Licenses, OnBoard Licenses) for a period of 90 days or 180 days.
    Shpat | ACEP | ACMP | ACCP | ACDP
    Just an Aruba enthusiast and contributor by cases
    If you find my comment helpful, KUDOS are appreciated.
