  • 1.  Exporting BSSIDs and AP Names
    Posted Jan 19, 2018 11:18 AM
    Hi, long time listener, first time caller.
    Does anyone know of a way to export all the BSSIDs and their associated AP Names either from the Master Controller or Airwave?
    I want to try and import the csv file into WiFi Explorer so the Annotations will display the AP names.
    Any help is appreciated.
  • 2.  RE: Exporting BSSIDs and AP Names
    Posted Jan 19, 2018 11:58 AM
    Hi-
    Give this a shot in CLI, it may be what your looking for.
    (7024) #show ap bss-table
  • 3.  RE: Exporting BSSIDs and AP Names
    Posted Jan 19, 2018 06:32 PM
    Second on what Jamie suggested, Another method is from Airwave - if you navigate to the monitored controller, you can run the above command from the CLI drop-down, export the text file cleaning, process it in excel (ap-name name-ssid-band)-checking for duplicates. I used to do this in the past for Wifi-Analyzer.
    #AirheadsMobile
  • 4.  RE: Exporting BSSIDs and AP Names
    Posted Sep 26, 2018 10:56 AM
    I had been trying to figure out how to do that for maybe 3 years... had no idea about being able to configure Wifi X to show AP name that way... problem solved.
    Thankyou Thankyou Thankyou
