Wired Intelligent Edge
Factory reset for OS-CX Switch Simulator
  • 1.  Factory reset for OS-CX Switch Simulator
    Posted Oct 24, 2023 05:17 PM
    I have the switch simulator up and running with GNS3 and as a test I had a couple of switches and did the initial login. I do not know if I fat fingered the new password or what but when I use admin as my password the switch in the simulator says wrong password. Is there a way to do a "factory reset" on the switch in GNS3? I have tried to uninstall/reinstall the appliance, but it did not work.
    Thank you for your help.
