Comware
  • 1.  Failover Router with VRF (VPN instance)
    Posted Oct 16, 2018 11:14 AM
    Dear All,
    I am begineer in HP and please help me .
    In my network we are using HPE 3044 .Now we run tow VPN instance (VRF ) in one  3044 route with 2 x WAN links. vpn instance 1 for customer type 1 (binding with wan 1) and vpn instance 2 for customer type 2 (binding with WAN 2). Now we want to add one router for fail-over.But i don't know which protocol need to run for randuncy.So IPlease help me which protocol or which service i need to run to get fail-over for this two router. VRRP can handle this topology ?
  • 2.  RE: Failover Router with VRF (VPN instance)
    Posted Oct 26, 2018 02:35 AM
    Hello
    To achieve redundancy between MSR 3044 Routers you can configure IRF.
    Two routers in IRF, will virtually be one and your VRF configuration also be need to go according to that.
    You want to explore more on this option in the configuration guides and post on more queries.
  • 3.  RE: Failover Router with VRF (VPN instance)
    Posted Oct 29, 2018 12:10 AM
    Hi @gc_09,
    Thank for your help.
    I need configuration sample.I aslo want to know  about sflow. My sflow configuration is doesn't work on MSR 3064 and PRTG. let me know my configuration is wrong not not i follow 6600 series configuration guide.
    https://support.hpe.com/hpsc/doc/public/display?docId=emr_na-c03129101
    interface g 0/0
    description LAN Network
    ip add 10.100.100.1 255.255.255.0
    sflow agent ip 10.100.100.1
    sflow collector 2 ip 10.100.100.2 description netserver
    gi 0/1
    description WAN
    ip add 10.10.10.1 255.255.255.240
    sflow counter interval 120
    sflow counter collector 2
