  • 1.  Fast Failover 6.3
    Posted Aug 08, 2013 01:48 PM
    I've configured HA and FastFailover and it works great. However, does anyone know what the preemption hold-down timer is set to or where it can be configured?
  • 2.  RE: Fast Failover 6.3
    Posted Aug 08, 2013 07:20 PM
    The timer is in the ap system profile. Once the connection with the active controller comes back, the ap will wait for x seconds as defined here until it flips back.
  • 3.  RE: Fast Failover 6.3
    Posted Aug 09, 2013 11:41 AM
    Do you know the exact setting in the AP profile? The only timer I see if the LMS Hold-down Period, which I wouldn't think would apply to 6.3 HA since the first thing you do is remove the backup LMS IP.
  • 4.  RE: Fast Failover 6.3
    Posted Aug 09, 2013 11:52 AM
    No. That timer does apply
    Sent from my iPhone
